Old 03-18-2008, 09:52 PM
beradtke beradtke is offline
Default paint products
ok i am almost to the point of painting the liner and floor in my boat. where i have repaired the floor an it is resin/fairing material. do i need to prime these areas or the hole boat? what is a good paint to use,I know there is interlux,pettit and awlgrip.What else is out there good to use? is there a good book i can buy,rent thats has good pointers on paints and what to do.
73 seacraft 80 merc my boat
Old 03-19-2008, 07:07 AM
Default Re: paint products
I used Sterling paint but you could use some of the other 2 part paints and do just fine. As for the method I would not skip any steps in the process patch up the holes, primer coat, one coat of paint, sand another coat of paint, sand, one coat of paint with grit. I thing the grit part on the walking surface is very forgiving to work with. I mixed both the fine and course grit together and doubled the recommended amounts of grit and I just rolled that on. Ship Shape did a program on painting the deck. You could buy that and watch it if you wanted.
FellowShip
Just for the Grins
Old 03-19-2008, 10:51 PM
thanks fello ship yeah i am getting really close.So now the hunt is on for which color i want and panit type. i am thinking light tan for the floor and white for the gullals and top cap.
Old 03-21-2008, 01:20 PM
johna johna is offline
I think I saw that someone here used Fabula's Signature Paint which I am considering. Looks like a lot less prep, no primer,just sanding if surface is in good condition. Also compatible with alot.Can match any color. Called him, very helpful seems doable for beginners like me. Almost seems to good to be true.
Anybody had any experience with it?
check it out, signaturefinish.com
Old 03-22-2008, 12:11 AM
Fishjack Fishjack is offline
Here is one of may threads about Sig Finish..
Sig Finish
Still looks great today and has really held up well to abuse and sun exposure.
Good luck.. Jack
1977 23' Superfish
ST250x Yam
Old 03-22-2008, 11:23 AM
Thanks for that reply, I see you did yours in '05. Looked great, I'd be real happy with that result.
Kind of convincing me it's the way to go.
I was considering the non-skid he has, if you used it, did you mix the fine and coarse like he suggests?
Old 03-22-2008, 09:01 AM
Default Re: paint products....Signature Paint
I will be trying out a test of this paint hopefully this weekend. I will let you know when I am through what I think
Old 03-22-2008, 11:04 AM
Signature after 22 years
(Touch-ups and Buffing prior to picture)
