Old 04-14-2008, 04:51 PM
76Red18 76Red18 is offline
Default V-4 gears in a V- 6 Lower Unit
A wile back I posted about different gear ratios in V-6 OMC lower units. I replaced a lower unit with what I thought was the correct replacement. Over time i suspected it had a lower gearing than the original but come to find out It's a lower unit for certian V-4's, I think!! The gearing is 2.25 to 1 which is specs for some "big lower unit" V-4 models. The lower units appear to be the same except for the gear ratios. First, does anyone suspect I'll have any strength issues with the V-4 gears? My motor is a 150. Second , knowing my ratio for sure lets me calculate a prop slip of .06 at W.O.T. Is that where I should be? By the way, I found out my ratio by turning the prop once and noting the timing wheel movement of 2.25 times so I'm sure of the ratio. Any comments are appreciated.
J. M. Hendrix
Old 04-14-2008, 09:05 PM
Ryank Ryank is offline
Default Re: V-4 gears in a V- 6 Lower Unit
Many of the v4's came with v6 style or heavy duty gearcases, I have switched many from a v4 to v6 etc with no issues. you should be fine, strengthwise as there is not a Giant power gap between a 135 or 140hp v4 and a 150 v6.
Seacraft's for life !!!
