23 seacraft classic vs. tracker made
could anyone help me out with when tracker marine took over seacraft boats...did the hull change? thanks
Re: 23 seacraft classic vs. tracker made
The replys I have been getting so far are the design is pretty much the same the production methods are different. Older hulls hand made newer hulls assembly line production
I THINK Tracker Marine took over in '87.
Common Sense is learning from your mistakes. Wisdom is learning from the other guy's mistakes. Fr. Frank says: Jesus liked fishing, too. He even walked on water to get to the boat! Currently without a SeaCraft (2) Pompano 12' fishing kayaks '73 Cobia 18' prototype "Casting Skiff", 70hp Mercury |
The hull, design, and materials stayed the same. The labor and rigging went up and down, the rigging mostly down since 1986. I have seen good and bad potter and tracker boats, I haven't seen a bad csy or mosely era boat, but that may be because there aren't many of those around. Whatever you do, if your not sure what your looking at, get a servey done on it. |
SEC = SeaCraft Inc (Potter 1969 thru 5/80)
csy = Carribbean Sailing Yachts (1980-1982 23'& 27' SeaCrafts only) SIC = SeaCraft Industries Corp (1980 thru 1987 other SeaCraft Models) (Potter on Board of Directors approx 1 year after sale) TXY = Sarasota Marine Corp ('86-'88 csy Parent Co) SIC = Tracker SeaCraft of Fla (1987 thru 1990) all models SXC = Stern Craft Corp (1994 Silver King Parent then Tracker Parent Co in 1995) MIC = Silver King Boats (1994-2002 Mako Marine Parent Co) MRK = Mako Marine (2002 Parent Co SeaCraft from Tracker
we need a lifeguard at the gene pool |
courtesy of "PETERB"
Before 1972 . . . Hulls had 4 digit serial numbers . . . so they do not have SEC in their HIN numbers. They will have been assigned one from the state where they were first registered unless that state supports 4 digit hin numbers.
Snookerd |
I would agree to the point they were heavier than they needed to be. Now on the other hand if you wanted to get in a fight with a dock or seawall that was good
They are the same hull and nobody has had any issues, most guys come out and say they love the new ones. There was 1 early 25 that was a nightmare for whatever reason, not sure of the real story as there are 2 sides always but that was 10 yrs ago.
Any way you measure it - dumbass is expensive |
Thanks for all the info on the history. I am looking at a 1989 23 CC and wanted to make sure that the boat, all things being equal, was as good as the earlier models.
