Old 06-30-2008, 12:05 PM
StrangeBrew StrangeBrew is offline
Default 1973 Potter SF - Fuel Tank Sending Unit Location
This season my fuel gauge stopped working and through a little trouble shooting, I've determined it is likely the sending unit that has failed. Assuming my fuel tank is original to the boat, does anyone know the exact location of the sending unit? If I could get at it through the deck without taking the center console off, that would be ideal, Thanks
Old 06-30-2008, 12:09 PM
Default Re: 1973 Potter SF - Fuel Tank Sending Unit Location
I should also note that it's a 20 footer
Old 06-30-2008, 02:14 PM
First, I wouldn't assume that it's the original 35 year old aluminum tank. But if it's configured the same, the fuel sending unit should be under the console, just to the inboard side of where the rigging comes thru the deck.
I'm not near my boat, so I can't give you an exact measurement. Hopefully you will find a "Pie" hatch already there.
Lloyd
Old 06-30-2008, 08:05 PM
Did you peg the gauge to make sure it`s working?
Old 07-01-2008, 02:18 PM
There is not a "pie" hatch in the deck and I'd like to try to avoid having to remove the console if at all possible.
How would I "peg" the gauge?
Old 07-01-2008, 02:43 PM
If the wiring is correct, the pink wire comes from the fuel
sending unit to the gauge. With power on, put a jumper wire from the back of the gauge "pink" terminal and touch the jumper wire to ground. The gauge if good will peg to full.
Usually you can hold the other end of the jumper in your hand with out any fear of being electrocuted touching the ground.
Sorry I cannot help as to where the sending unit is on your tank.
See ya, Ken
Old 07-01-2008, 03:04 PM
76Red18 76Red18 is offline
Can't help you with the location either except for the fact that mine is at the rear of the tank on my 18. I'll also re-post NoBones' link to WEMA sending units. I'm finally getting around to replacing mine as I'm really feeling the need to get offshore for some permit tug-o wars. Orderd the unit Sunday and it arrived this morning. Well constructed insturment. What like most is there is no electricity exposed to gasoline.
web page
J. M. Hendrix
Old 07-01-2008, 08:07 PM
`89 20 sf pie plate behind console in middle of coffin cover.
I had to re-core my coffin cover and did not have to do a complete disconnect as the wiring had enough slack. Popped the console and put 3 2x4`s under for support.Slid right out. I have the wide console though. 42" flange to flange.My coffin hatch is 8`1" x 26 1/4".
I also have a gauge on top of the sender. Remove and clean the crud out. Test w / a small round magnet on the bottom by following the arc from e-f. Needle should peg.
GFS
