Old 07-10-2008, 05:08 PM
Default Aluminum Rod Arch Paint
Hi All,
I just picked up a tired rod arch for the Seafari. I'd like to clean it up and use it but want to remove corrosion and protect it as it is certainly serviceable. Any thoughts on products or processes to:
1. Remove corrosion
2. Prep for primer
3. Primer product
4. Paint product
Thanks, McGill
Old 07-10-2008, 09:05 PM
castalot castalot is offline
Default Re: Aluminum Rod Arch Paint
flitz metal polish can do some amazing things
Old 07-10-2008, 09:06 PM
Marine aluminum is normally anodized. If it's worn away the best thing would be blasting and powder coating.
Old 07-10-2008, 10:45 PM
Unfortunately it's not anodized, so it has taken a beating. I'd like to get it powder-coated but not sure if its worth it. Don't know much about aluminum other than beer cans but I've seen some nice paint jobs on them so I thought maybe paint would preserve the arch for a few more years. I'll look into the flitz too, castalot. Thanks.
Old 07-11-2008, 09:16 AM
Gilly
Click on the links
1.) Remove Corrosion ------> SALT X
2.)Prep includes Wire Brushing, Sanding and then Filling Holes & Deep Pitting ----->EPOXO 88
3. Paint-----> Call Tom, he will walk you thru the process. NO primer is needed. Do it yourself paint. Tell him I sent ya ---------> Signature Finish
Old 07-11-2008, 09:37 AM
BigLew BigLew is offline
This is probably overkill, but I'll pass it along anyway. It also might help with other issues that your arch may have.
http://www.aluminumrepair.com/
Good luck.
Plan accordingly!
Old 07-12-2008, 09:20 PM
Thanks for the links Capt Chuck. That aluminum repair stuff looks interesting, too Big Lew.
Old 07-14-2008, 10:38 AM
If you look at the Awlgrip prep book it talks about painting aluminum. Theres's a chemical prep process using Alodine that turns the surface of the aluminum into something the epoxy primer will adhere to better.....as well
as the epoxy fairing materials.
Old 07-14-2008, 06:07 PM
If your aluminum has pitting from salt water environment Chloride corrosion you must first get ALL of the corrosion off before you give it the chemical wash or It will not protect your work and the paint will bubble in approx 6 months. If you just try to epoxy over the top and then paint it will bubble as well. You must get all corrosion off first then the two part chemical wash then a coat of epoxy then primer then paint. If not you are wasting your time “if there is Corrosion” on the aluminum trust me on this on.
Fellow-Ship
Just for the Grins
