Old 07-14-2008, 09:01 PM
abl1111 abl1111 is offline
Default West System and Fuel
Can the West System withstand fuel ? Or is there a better epoxy / (2) part epoxy for a gas application on an aluminum tank ?
Old 07-15-2008, 01:47 PM
Default Re: West System and Fuel
Hi Abl
What are you asking? Is the tank leaking and you are trying to plug it up or what.
Fellow-Ship
Just for the Grins
Old 07-15-2008, 04:17 PM
Rich Rich is offline
If your looking to coat a new tank on the outside use this stuff. http://www.por15.com/
There is a tank builder in RI that built my tank and they said they coat everything with it, and they have been using it for years.
Cape Marine Supply
Old 07-16-2008, 05:42 PM
I have a small aluminum fuel tank that is leaking at a seam. I removed all the fuel, and used West System yesterday on it ( West and microballoons ). It's cured, I'll add fuel today and let you know how it goes.
Old 07-17-2008, 06:02 PM
So far so good.
I sanded the area w/ a 120 grit grinder. Cleaned w/ acetone. Brushed on West System then added West System w/ micro balloons to consistency of mayonaise - put that on top w/ a nice thick bead. Let set overnight. Grinded smooth to a 1/4" thickness.
Fuel proof so far.
Old 07-17-2008, 07:56 PM
kennmazz kennmazz is offline
Throwing in my two cents. I just got my tank repaired at a fuel tank fabrication shop. They advised me to paint it with cold tar epoxy. I found it available at a local paint store. It was $60 a gallon. I haven't put it on yet. Any ideas on where to get the rubber strips that were under the tank?
"To know what is right and not do it is the true cowardice." -Confucious
Old 07-17-2008, 08:17 PM
I just found the neoprene strips at Jamestown distributing.
