Old 11-26-2008, 12:44 PM
Default Trim/Tilt Pump on 225 Mercury
Ok people, my starboard motor trim/tilt pump is humming, but takes a minute literally to move. Is there a fluid fill on it or is it DOA??
Old 11-26-2008, 04:06 PM
Default Re: Trim/Tilt Pump on 225 Mercury
You've probably already resolved it but, hum and slow does sound like low hydraulic fluid, or low battery/bad contact. My last hum was low reservoir (re-filled). See any fluid or film around trim hoses that may suggest a hose, o-ring or fitting leak? Don't know yer motor so don't know about refill... What year models are your motor and trim motor? I think most of the late models have fill hole on port side near top of reservoir. Usually @ least a 1/4" screw or bolt.
Old 11-26-2008, 07:38 PM
im not sure about the 225 tilt bracket but on my mid 90's 200 bracket when the engine is up there is a fill screw on the left side of it. if you open it and no fluid comes out it might need some fluid. fill it till its full and runs back out put the screw back in and try it out. i used regular atf in mine.
Old 11-27-2008, 12:43 AM
sounds good. thanks for the help. these 1996 225's have been running well,ask Briguy we got close to 60mph before she got a bit to tuff to control at the Desoto Gathering. With gas back down, using the boat makes sense again
Old 11-27-2008, 07:19 PM
Danny, sounds like low fluid...
Check for residue of fluid around the ram seals.
Go to any FBO, (Airport) look for any flight operations
and get a gallon of red hydraulic fluid. ATF is Ok, but
the red has no bad stuff in it that can further damage
your seals. Texaco brand is what I have always used
in the TNT and the Bennett reservoir..
See ya, Ken
Old 11-29-2008, 02:59 AM
thx Ken! I will check it out.
Old 12-02-2008, 05:40 PM
Briguy Briguy is offline
For sure sounds like low fluid. ATF worked for me in my old yami's. You may want to take off a lid from some other container that has a little pop up thingee. It makes it easier to squirt in the little hole without getting atf everywhere.
Also I think the gps said 65 not 60!
Capt. Brian
Old 12-02-2008, 05:59 PM
I use an old "Slime" tire sealant bottle, with an 8" piece of 5/16 clear plastic hose pushed over the nipple on the bottle.
Old 12-02-2008, 06:59 PM
Roger that! Thanks guys.........
Old 12-07-2008, 10:08 PM
bridgeman bridgeman is offline
Snookered, I see you have twin 225's how does the hull handle them in relation to the scuppers? I just bought an 81 it also has twins, the previous owner had plugs laying on the floor next to the scupper drains so I kind of figured they would be neccessary, I have yet to put the boat in the water no heartburn if I have to use them. Can't wait till spring to try her out..gonna be a long winter.
