Old 12-12-2008, 05:55 PM
toehead93 toehead93 is offline
Default 21 Seacraft
I may soon be a happy Seacraft owner. I'm looking at a 1982 21' Seacraft tomorrow. I've been looking for the past year or so at the 23 Seacraft on this site and elsewhere so I don't know too much about the 21 other than it is a Tracker built boat and has the same hull design as the 23' (just shorter). Are these hulls all fiberglass, I thought SC stopped using wood stringers in 1982(?). Also, what are some things I should know before I make the decision to purchase, any inherent problems?
The boat was upgraded in 2002 and it looks very clean so I'm pretty optimistic.
Old 12-12-2008, 07:03 PM
Default Re: 21 Seacraft
Check it carefully. SeaCraft didn't build a 21' in 1982.
Old 12-12-2008, 07:06 PM
Woops, too late to edit. It is a 1989 21' Center Console.
Old 12-12-2008, 08:04 PM
jongolds jongolds is offline
There are far more knowledgeable people here but, I don't think they ever built a 21' center console and I don't think they ever had wood in the stringers. The transom and floor were wood cored but the stringers were foam.
1973 23' Tsunami, 300hp Etec
Norwalk, CT
Old 12-12-2008, 10:45 PM
i Don't believe SeaCraft starting building the 21 until the late 90's- I have a 2000
Old 12-13-2008, 01:28 AM
... I don't think they ever had wood in the stringers.
Tracker was foolish enough to put plywood-cored stringers in some of the 23's beginning in '87 or '88, I'm not sure I remember correctly. But we repaired a 23' Walkaround that had been hit by a 21' Scarab going 40+ mph in the dark. We had to repair the aft port hull to transom corner, and the stringers in that Tracker SeaCraft were cored with 3/4" plywood. I was absolutely shocked, as I knew about the hollow fiberglass stringers that were part of the SeaCraft mystique.
Old 12-13-2008, 07:56 AM
Just for the sake of arguement, I am redoing my 1970 20' cc, the stringers where hollow, yet there is some 3/4" ply used for forming strips of some kind, inside the stringers, needless to say, there was not much left of the ply.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 12-13-2008, 01:19 PM
In '89 I believe the 20-footer was 20' 4" LOA, so the seller may be rounding up and calling it a 21'.
Old 12-13-2008, 04:28 PM
Mark Mark is offline
I think 1989 is about a decade too early for a SeaCraft 21' CC.
