Old 02-11-2009, 06:21 PM
natchalkley natchalkley is offline
Default questions about recoring hatches
I need to recore the hatch that covers the fuel tank. my question is do I want to got with a single piece for the core or do I want to cut squares? I would think that the squares would make it easier to make it flat, but im not so sure about the strength. is it strong enough like that or should I go with a single piece?
Capt. Nat Chalkley
Get the Net Charters
http://www.gtncharters.com
http://www.getthenetcharters.blogspot.com
Old 02-11-2009, 08:39 PM
red20 red20 is offline
Default Re: questions about recoring hatches
did mine w/ squares and it worked out fine.
Old 02-11-2009, 08:50 PM
Gary Hill Gary Hill is offline
I did mine with marine plywood 10 years ago and are still solid. (one piece)
GARY
76 SEACRAFT CC INBOARD
Old 02-12-2009, 09:20 AM
The basic reason for the squares are so they conform to any crown that you might have. If your area is flat one piece will work fine.
A while back some one who is in the marine boat building business said that when he first started his job was cutting up the scrap plywood into squares..
What's the new buzz phrase...Re-claim, re-use, re-cycle.
Old 02-12-2009, 10:10 AM
bigeasy1 bigeasy1 is offline
I did mine with one piece of 1/2" marine plywood,and it worked great.The original was 6x6" pieces,but seeing as the hatch is flat,one piece worked good for me,and was quicker to accomplish.
All this,just for a boat ride
Old 02-12-2009, 10:12 AM
hermco hermco is offline
Using squares or a full sized piece cut into sections also reduces the chance of getting a large air pocket between the core and sunstrate.
Old 02-12-2009, 01:36 PM
Briguy Briguy is offline
Or: USE IT UP, WEAR IT OUT, MAKE DUE, DO WITHOUT.
Capt. Brian
Old 02-16-2009, 12:31 PM
jonesg jonesg is offline
A large unsupported layup can easily buckle due to sun heat.
A molded lip won't always prevent it from twisting.
Old 02-16-2009, 07:27 PM
I did mine with nidacore and they've been holding up well for three years.
Old 02-22-2009, 11:34 AM
nat - use the squares. There is no advantage to using 1 piece of core. The strength comes from the skins, not the core (which is why you could even use balsa wood or nida core) As hermco said you risk trapping air under a large sheet. Squares also make a stiffer laminate.
