Old 02-26-2009, 02:11 PM
Default Fuel tank question w/pic
I need to credit Bonefish and his gorgeous 23' for this picture. It's the best example I can find.
How would one inspect the pick-up tube in this picture?
Is the tube small enough to slide through the male npt boss welded to the tank?
Old 02-26-2009, 02:57 PM
Default Re: Fuel tank question w/pic
usually the tubes are welded to the tank with the elbo threaded in, sometimes the tubes are threaded in, depends on who made the tank, sometimes there is a screen at the bottom which is a P.I.T.A, if it's clogged you might have to put another tube in with a flange similiar to the fuel sender.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 02-26-2009, 03:22 PM
gss036 gss036 is offline
Looks like there are 2 pick up tubes for dual engines. Are they both clogged, maybe switch the fuel hose around?
Gary
Old 02-26-2009, 05:15 PM
In the picture shown, the far right fitting is the one in question. The female threaded fitting is welded to the tank and (I believe) the anti-siphon valve screwed in. The other two are fill and vent. I want to know if the pick-up tube is removable through this threaded fitting??
Old 02-27-2009, 09:52 AM
Sometimes yes, sometimes no, depends on who made the tank.
1974 40' Eagle
www.parkeryacht.com
