Old 03-31-2009, 06:23 PM
Vaguada Vaguada is offline
Default Flushing the motors
Hi! How long did an outboard motor should be flush? Its 5 or 6 minutes enough?
Thanks to the masters...
Old 03-31-2009, 06:33 PM
Default Re: Flushing the motors
that should be fine. i ususally run mine for about that time. i just let the stream get warm then shut it off
Old 03-31-2009, 08:04 PM
You don`t want to flush a motor at more than half of the spigot volume on the muffs. The reason for this is that you can hydro lock the water passages with too much volume and not get cooling up to the top pistons on some motors. Motors have blown on the muffs because of this!
GFS
Old 03-31-2009, 08:20 PM
castalot castalot is offline
thats a new one.......interesting though
i've heard of not reving the engine idle to 1000 rpm only
what kind of motors are you refering to?
Old 03-31-2009, 08:40 PM
96 ocean pro 150
Old 03-31-2009, 08:59 PM
Until last year I never had issues on muffs. Run (Mercs/JohnRudes) until the thermostat opens and consider the flush complete. That said my new to me Yami 130 2 stroke (first yami for me) will not run on muffs. It runs, a few min pass, and the overheat alarm goes off. After replacing 100% of all cooling related parts the solution was....you need to run it in a barrel . For some reason on muffs the bypass wont open allowing water to heads. The one upside to this is my neighbors and I learned how much more quite running in a barrel is . This year I make a dedicated flush tank.
1974 23SF
Old 03-31-2009, 09:06 PM
good to know my motors are 95's but i usually use a barrel as well
thanks
matt
Old 04-01-2009, 12:38 AM
what did you make a flush tank out of?? i kinda want one too.
Old 04-01-2009, 07:56 AM
Havent made it yet. When I do it will have a drain @ the bottom.
1974 23SF
Old 04-01-2009, 08:40 AM
fishing_fanatic fishing_fanatic is offline
I have the EXACT same problem with my 95 130 Yamaha! Runs fine in water but on muffs the alarm goes off after a few minutes. I put a bungie around the muffs to tighten them up and better seal around the intake but basically I dont run it long and dont rev it.
Had a mechanic say this is typical with Yamahas, too much water leaks out where as it doesnt in water or a barrel.
