Old 04-14-2009, 03:12 PM
Splitseas Splitseas is offline
Default Soft spot
Hello everyone. I'm new on here and have been reading a lot of the info posted on repairs by others. I have a 1973 20' CC. There is 1 soft spot between the console and the port side. My question is, can this be repaired w/out cutting the floor? I was wondering if you could remove the deck above the gas tank and repair from underneath? Any suggestions are greatly appreciated. Thanks!!
Old 04-14-2009, 04:38 PM
Default Re: Soft spot
Being a 73' I'm not sure whether your deck is plywood or balsa, I'm sure someone will pipe in that knows, I do know that it would be VERY hard to fix from underneath,if not impossiable, there will be a stringer between the tank and the spot, you need to determine if the deck is wet or if there is delamanation or a void between the fiberglass and the plywood or balsa, if it is dry I would drill some small holes and inject epoxy till they come out the other holes. If it is wet you could cut a square out, dig out the wet balsa and fill with coring and put the deck piece back in, just my 2c.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 04-14-2009, 05:19 PM
fdheld34 fdheld34 is offline
My '72 has balsa. I thought I had a soft spot but it was discovered after cutting top skin that it was only delamination and no rot etc anywhere..looked like brand new core. I dont know if there is room enough to get to underside from fuel tank area????. Drilling holes and filling epoxy is a way to go if you dont want to cut skin...just dont drill too deep!!!!
-Fred
Old 04-15-2009, 01:21 PM
Thanks for the help guys, greatly appreciated!!
