Old 04-29-2009, 10:02 PM
formakos formakos is offline
Default 1974 20' CC
Negotiating to purchase a 1974 Seacraft 20' CC. What areas should I be looking at as far as problems that I may encounter? Thank you for your input.
Old 04-29-2009, 10:10 PM
PressureDrop PressureDrop is offline
Default Re: 1974 20' CC
is there in echo in here... the search function will reveal allot of useful information, in a nut shell, check the transom, if its origional chances are its no good anymore, deck is easy, walk around everywhere check for soft spots, esp around where anything is screwed/bolted down. stick your head everywhere you can, touch and bang on stuff (not to hard now) if the gas tank is foamed in under the deck and is origional it will need diligent inspection... thats just scratching the surface, im sure others will chime in
no falls, no balls
