Old 05-12-2009, 03:34 PM
doughert0 doughert0 is offline
Default motor mount height on '67 bowrider
Bushwacker recently responded (5-2-09)to a thread in the classic seacraft forum in which I asked if a 90HP motor would be OK for my 19-8 Seacraft Bowrider. I presently run a 115. He mentioned that the cav plate should be 1" to 1.5" above the bottom of the transom Vee. I finally measured mine, and it is less than 1/2".
Many years ago, not realizing that the transom was set up for a single engine 25" shaft, I bought a new engine with a 20" shaft and cut the transom. (When I bought the boat, it had twin 60's.) I had no guidance at the time, so the cut
was designed to make the cav plate come out about even with the bottom of the Vee.
I can increase the height of the cav plate to 1-1/4" by raising the motor one notch. As Bushwacker pointed out, my performance seems to be very poor - could this be
because the motor is 3/4" too low? Also, at WOT, the top of the prop is out of the water. So I always thought it might be too high!
The consensus answer to my question was that a properly set up 90 should give me at least as good performance as I am presently getting with the 115.
Any comments or suggestions?.
