Old 05-20-2009, 09:06 AM
thedog thedog is offline
Default new member, wanting to compare performance 23cc
hello all, I just purchased a 23 cc 1998 back over the winter.
not a classic but the boat only had 8hrs on new power
it is powered by twin 150hp etecs, I say the boat rides very nice. did alot of work over the winter rewiring and taking care of the hull.
seems to me that this boat with 300hp should be making better speed on the top end.
at 3500rpm I am running 29knts
at 4100 35knts
at 5000 wide open 38knts
I am reading speed via GPS and could be a problem with GPS speed
if anyone has a similar boat and power, please do me a favor and post some perfomance stats of your boat
thanks
Old 05-20-2009, 09:15 AM
Ryank Ryank is offline
Default Re: new member, wanting to compare performance 23cc
Sounds about right from others I have seen,it would be faster with a single 300, even a single 250 in my opinion. My single 225 on a very heavy 23 Savage produces roughly the same top end.
Seacraft's for life !!!
Old 05-20-2009, 09:18 AM
peterb peterb is offline
I used to have a 23' with twin 150 Yamaha SWS's. It would top out around 44 MPH. Since the engines were carb, I would avereage about 1.6 miles per gallon.
The SeaCraft hull rquires power to push it. I have a friend who has a 23' Parker SE CC. He can push his boat with a 200 HP, and can move quicker & gets better mileage than a 23' SeaCraft with a 225HP.
I now have a 23' SeaCraft with twin Yamaha 200 HP OX66's. This boat I can push into the mid 50's.
Any idea on what your RPM's on the ETC's should top out at? Have you considered different prop's?
Peter
Old 05-20-2009, 10:37 AM
thanks for the input
the motors are rated for 4850-5500 flat out
so I feel I am at the largest prop I can fit without lugging the motors
have yet to get any kind of fuel burn numbers and efficiency stats out of them
they seem to purr along at 3500 rpm
would be nice to find someone with the etecs on the same boat and see if they run the same.
Old 05-20-2009, 10:43 AM
'73 23' CC w/Alum. bracket/250 Yam. OX66 w/17P prop...low-mid 40's at 5500 rpm. avg. fuel burn is 2mpg if you don't keep it pegged.
Old 05-20-2009, 03:31 PM
dropping 2" in pitch would probably help out on the hole shot and top end - that should get you about 5400
Old 05-20-2009, 05:45 PM
That's pretty good - 44mph...considering you've got 900 lbs on your tail end. I presume you have trim tabs. Different prop, depending of course on what your current shape is, might give you more stern lift. Lower pitch might add some rpm, but I think you're past your speed gains curve rpm wise. If you have a a t-top that adds a little drag, too.
Old 05-20-2009, 09:19 PM
gss036 gss036 is offline
I think a couple of Power Tech 4 blade stern lifting props would get you better mid range performance, especially on fuel. That is a lot of weight on the back of that boat. I am running a Honda 225 on my SeaCraft 23WA and run better than that. I am no speed demon, so 35-3700 RPM at 27 MPH suits me just fine. I think WOT gives me 42-44 MPH.
Gary
Old 05-22-2009, 09:03 AM
Gary how do you like the power with the Honda? I have been thinking of going with one, and have seen several 2-3 yr old ones in the 7-8k range. the last Hondas I had ran fine at over 5k hours. My biggest concern is performance with 3-4 divers and 8 tanks.
Old 05-22-2009, 01:38 PM
I really like it. Once I got rid of the proposing by raising the engine and putting on the Power Tech 4 blade stern lifting prop, it performs super. Great fuel economy at mid range, which is where I run 99% of my time. We just have too much junk in the waters here to safely go much faster.
That is a lot of weight, can't offer much advise there.
Gary
