Old 07-10-2009, 04:45 PM
Rich Rich is offline
Default Need help locating an Air Jet for Yamaha carb
Took the carbs off a 1988 Yamaha 175 to clean out the junk. When I was reassembling the last carb, I was tightening the Main Air jet (which is a little brass screw with a whole in it to allow air into the carb)and the head of the screw broke in half. I was able to back it out and the carb is fine, so i just need a replacement. Here's the kicker.. Yamaha no longer sells the part individually and they don't even list it with a part number any more. The only way to get a replacement is to buy a new carb for big bucks.
The size of the main air jet is 200.
I have scoured all the local outboard shops looking for a replacement. I have found 190, 210, and 270. I can not locate a 200 anywhere.
Does anyone know of some back alley shop that would carry a bunch of older Yamaha carbs that could be parted out or bought full for a reasonable price?
Thanks.
Rich
Cape Marine Supply
Old 07-11-2009, 09:54 AM
76Red18 76Red18 is offline
Default Re: Need help locating an Air Jet for Yamaha carb
As long as the hole in the jet is not disturbed you can file the rest of the broken head off and carefully cut a new slot for the screw driver. The diameter of the jet's hole is all that matters. I have 2 of 6 like that in my 150 Johnson. Not sure of the thread size of your jet but go to a hardware store and find a nut with the same threads, wrap a tiny bit of black electric tape on the jet thread and screw it into the nut. You can then hold the nut with pliers or a vice while filing the jet.
J. M. Hendrix
Old 07-14-2009, 11:22 AM
asdfhood asdfhood is offline
It is possible to redrill a jet. Possibly the next size smaller could be located and redrilled to a 200.
Old 07-14-2009, 01:19 PM
Thanks for all the suggestions. I actually found one in MO of all places. Really helpful people over at http://www.yamaha-rebuild.com/.
If I couldn't find one I was going to get a 190 which is a little smaller and bring it to a machine shop and see if they could drill it out to a 200 spec.
Rich
Cape Marine Supply
Old 07-14-2009, 02:50 PM
Try the back of Eagle Marine in Sagamore. They had a little scrap pile when I was there the last time. Not sure if they will allow it, but it doesn't hurt to ask.
