Old 07-13-2009, 04:24 PM
jwclbi jwclbi is offline
Default steering issue
I am doing work on a friends boat with a steering issue. The issue being he told me it is very hard to steer while on plane to the right. He has the teleflex cable style steering which i disconnected from the outboard and it steers both ways with ease. The engine as well moves back and forth with ease without the cable attached. He has also adjusted the skeg above the prop. Im wondering if it is the torque of the prop?? I have run bigger outboards with the teleflex and they didnt act like this. It is a 115 2 stroke Johnson. Also the skeg below the prop has been snapped off by the previous owner, but im not sure that would have such an effect. Any thoughts or in put would be great, thanks.
Old 07-13-2009, 05:31 PM
76Red18 76Red18 is offline
Default Re: steering issue
its the broken skeg causing the steering torque
J. M. Hendrix
Old 07-13-2009, 07:23 PM
Richard is very correct!!! Especially at high speed.
Old 07-14-2009, 03:09 AM
Other than the cable gets kinked when hooked up to the motor, which you could enlarge the hole where it comes out of the hull - thats the only thing I can think of.
Old 07-15-2009, 11:12 PM
Propeller torque, amplified by a broken skeg.
