Old 07-26-2009, 02:43 PM
Default Seafari 25 galley seat
Here are some shots of the galley seat. Originally, there was an alcohol stove which would sit inside the sink when stowed. My grandparents had a small fire while using the stove years ago. I took it out and now use the space for either the barbeque or Coleman stove which I stow under hatches in the cabin. Our sink draws from a thru hull, right from the lake but I will eventually put a freshwater tank in and an electric pump.
[image]http://[/image] [image][/image] [image][/image] [image][/image] [image][/image]
Old 08-02-2009, 02:28 AM
Default Re: Seafari 25 galley seat
I also use that space for my home away from home office
[image][/image]
U gotta love surfing Classic Seacraft on a classic Seacraft
Old 08-02-2009, 07:23 PM
stumpie2 stumpie2 is offline
GOTTA LOVE IT... BET THOSE CC GUYS CANT DO TRICKS LIKE THAT...LOL
Old 08-02-2009, 07:35 PM
Mike5000 Mike5000 is offline
Brandon,
I'm planning to do the same with my Sea Master. Picked up a 3000 watt power inverter that I'll be installing. I also plan on a adding a small generator as well for some night fishing power. I spent the today tracing all the wires out and what a mess. I found red wires spliced to black wires. Wires running to nothing, it was a mess. I like the sink compartment you have under the seat. What type of propane stove are you using on your boat? I am planning on adding one but I wasn't sure if a propane stove in the cabin would be safe.
Mike
Old 08-03-2009, 10:44 AM
[image][/image]
That is so wrong.. never call a SeaCraft an office.. that laptop should be a blender, lots of rum in it...
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 08-03-2009, 04:24 PM
BigLew BigLew is offline
Hey Pipedreams,
seafari25 didn't go to work today, he went fishing and was going to do "just a litle work" like he's done everyday day for the couple of weeks!
Plan accordingly!
Old 08-04-2009, 01:29 AM
Brandon,
Mike
Mike
Nice looking Sea Master! The rare models are really coming out of the woodwork these days.
You should have no problem running anything with a 3000 watt inverter. I use a 400 watt which does the trick for charging my phone and laptop. It's not enough power to run a blender though...
The propane stove I use is a Coleman 2 burner. Typical of what you would see people using while tent camping. It uses the small disposable propane tanks, similar to a plumbing torch tank. These tanks also work for my BBQ as well. For your application, I would think that you might want a flushmount and plumb it to an external tank which you would keep out of the cabin. you could also plumb it to a fridge or BBQ OR you could go with an alcohol or alcohol electric. There are quite a few options out there.
Good luck with your project.
Old 08-05-2009, 11:03 AM
Thanks Brandon,
I think I will be able to run a blender and a wine chiller I’ll be using for the vodka. I thought about using a larger propane tank but I wasn’t sure how safe that would be plus I don’t have much space. The boat has dual fuel tanks and two freshwater tanks. One for the sink and head the other for wash down. I hope to get it all done soon being several people are catching sailfish a mile or so offshore right now. I saw one inside the jetties chasing bait about a month ago but thought I was seeing things. Check out June 4 pictures on the link below. Some woman caught one around the Port Aransas Jetties.
Mike
http://corpusfishing.com/porta.htm
