Old 09-11-2009, 10:52 PM
yakbass yakbass is offline
Default 18sf trailer help needed
The trailer under the 18sf I just bought failed two hours into a 12 hour drive and I need to get a new one. Question is what capacity? Most have recommended a 3100lb capacity. It will be a Loadrite roller.
Mike
Old 09-13-2009, 01:31 AM
Default Re: 18sf trailer help needed
I would reconsider to an Alum float on/drive on - so sweet to load and unload
Old 09-14-2009, 10:47 AM
Mike
Mike - What failed? Bearings? Brakes? Axel? Leaf springs? . . . Lights?
You might want to just fix the problem with the trailer . . . Unless the frame is rotten . . . it's a whole lot cheaper to fix what you have now.
Old 09-14-2009, 01:04 PM
Greno Greno is offline
I have an 18' and a Magic Tilt aluminum trailer. My axle is rated for about 3000 pounds. I just got the boat a few months ago and the axle is too small for the load. I am going to get a 5000 pound axle. It is currently eating the inside of the tires pretty good.
Eric
Old 09-14-2009, 06:47 PM
rickg rickg is offline
I took my rig to a weigh station and ot weighed 3020lbs with 20 gal fuel.I also have 3500lb axle with springs rated at 1750 apiece on 14 rims.
Old 09-20-2009, 02:11 AM
justlivin81 justlivin81 is offline
I would recommend a Float on/Drive on trailer. I also have a 18SF and have a dual axle Float on trailer. I made a 8 hour drive with now complications. I also checked everything on the trailer before hand ( tires, bearings, lights, etc.) and did not take the trailer over 70 mph.
