Old 09-23-2009, 02:59 PM
pl99 pl99 is offline
Default Anchor box not draining... HELP PLEASE?
Ok I have Used a plunger, a snake, went to the car wash and shot water in drain hole... Rain a snake from under live well to as far as I could get It....
It has done this in the past but usually one of the above works...
Water was full of old debris at first and nasty.. Now its clear and still not draining.. I have checked for old posts and could not find anything... Thanks any help is appreciated and will take any one out fishing when macks start running/boat has rs lic. so 3500 lbs aday limit.. Just dont want to start cutting Which I am pretty sure I might.. Thank s yall Chris L hull is 73 CC 19 6
Old 09-25-2009, 01:06 PM
Default Re: Anchor box not draining... HELP PLEASE?
I would try some air. Start with a lower pressure and work your way up. I'm guessing the line cannot be accessed so cracking it with 100psi would be a bad thing. You may just have a kink in it that some muck has clogged it. Where does it drain to? Maybe you could unclamp one of the ends and twist it, maybe whatever is causing the kink will hit a different spot on the hose.
Old 09-26-2009, 12:07 AM
Hey thanks, alredy fixed it. LOADED with sand seaweed and about a milllion other things.... Snaked it for three hours the other day till water ran clear..
LOADED WITH Crap.... Literally three hours till water ran threw clear in the hot fla sun..
Chris
Old 10-11-2009, 03:34 PM
publius publius is offline
I think I might plug the exit end and fill the drain pipe with something like Simple Green and an algaecide and let it sit for a day then pull the stopper and flush.
