Old 11-05-2009, 06:05 PM
Default Merc Tower housing
anybody have a 200 Merc tower housing with a decent swivel pin - 20" - I lost a cylinder but my swivel pin needs work anyway so I either buy a whole engine to get the swivel pin and sell the LU or rebuild mine and find a tower housing
Old 11-05-2009, 09:11 PM
Default Re: Merc Tower housing
Hey Dixon - I think I can hook you up!! I have a few options for you . . . as you know the steering arms and bottom yokes on mercs get nasty real fast in Saltwater. I have 3 or 4 clean ones. I'll call you over the weekend.
Old 11-06-2009, 03:51 AM
I knew you would have 3 or 4 of everything LOL - I just need the pin itself, my trim and stuff is fine just have some play when I push on the motor
Old 11-06-2009, 07:35 AM
Dixon, did you already have the play, but waited til you had to pull the powerhead before addressing it? I ask because the pivot pin on my little Merc 70hp 3 cyl needs replaced, and i have been avoiding pulling the powerhead.
Old 11-07-2009, 06:18 PM
Just noticed it last week when I pushed on the motor for some unknown reason - I talked with a guy that has a mid down in Pinellas Park and he said he did his without pulling the PH - the allen screw on the shift shaft can be an issue though
So I may have one lined up down here and the guy said I could do some of the work myself - I want to aviod having to swap the T & T unit if possiable
One more opinion needed - he thinks by pulling the reed plate I could get to the rod cap for #6 and push the piston out - hone the cylinder and put a new piston in without dismantling the PH - all the others are fine and I don't expect the cylinder to be too bad. I would have Mike help me with this part if its feasable - hate to part it out
Old 11-11-2009, 02:44 PM
Looks like the block is fine, just some alum to be sanded out. This guy I found thinks he can do the swivel pin without pulling the PH just the pan and then will pull the reed blocks and pump a new piston in it. Gonna try it anyway and it keeps the labor costs down.
Old 11-13-2009, 12:00 AM
http://tampa.craigslist.org/pnl/boa/1462777430.html
Old 11-14-2009, 03:52 PM
The guy thats doing mine is close to there and I'm giving him a hun for it and its tight - I saw that one but this guy has a shop and will do all the work - piston and all
Just a note - I was talking to a guy in SC about a PH - mentioned I had some Alum on the cyl wall - novel idea but he said just put some muratic acid on a rag and it will come right off - no sanding, makes perfect sense too will report back on that shrimpin - just an FYI
