Old 11-18-2009, 06:01 PM
morgan morgan is offline
Default 1970 20' deck job, to foam or not?
replacing the deck on my 1970 20 cc, had to dig some foam out to repair the stringers(about a 6" wide channel on inboard stringers) was wondering if it is really worth it to replace the foam or just leave it. Does it have any structural purpose?
Old 11-21-2009, 11:24 PM
lonesurfer87 lonesurfer87 is offline
Default Re: 1970 20' deck job, to foam or not?
Don't replace foam take as much out as you can especially on a boat that old. I have seen foam that is supposed to float taken out of an old formula that the foam itslef actually sunk it was so water logged. Look at all the restore jobs on here everybody takes foam out and leaves the area between stringers foam free. Hope this helps.
Old 11-22-2009, 10:55 AM
The main purpose of the foam is to give the glass mat shape. All the strength is in the mat. If the mat around the foam is separating from the hull re-glass that and you should be good to go.
