Old 12-13-2009, 01:16 PM
nitz nitz is offline
Default Non skid options?
What do you guys think is the best non skid. Has anyone used linex or other bed liner? I have done the awlgrip w/ griptex before, but it was hard to keep clean.
Old 12-13-2009, 02:06 PM
bigeasy1 bigeasy1 is offline
Default Re: Non skid options?
I did the deck of my Tsunami with thickened gel coat.It is a super non skid.I think I could get a running start with fish slime in the deck,and still not slip.
However,I thickened it up a bit to much,so it's a very aggressive non slip.If you did fall on it with shorts on,there would be a bad case of road rash.
It's also a bit difficult to keep clean.If I did it again,I'd knock the texture down a bit with a dry roller before it cured.
All this,just for a boat ride
Old 12-13-2009, 02:41 PM
bridgeman bridgeman is offline
Might be overkill but this is what I'm looking to put on my floor this spring. http://www.nonslipcoating.com/marine.htm
Old 12-13-2009, 07:11 PM
I used Linex on my 20 and I am very happy with it so far. It is a little on the costly side but nothing is too expensive for a seacraft.
Old 12-13-2009, 08:54 PM
cdavisdb cdavisdb is offline
I just finished looking at a spray on truck bed liner as a nonskid coating for a dive platform. Decided against it for two reasons. It would be great non-skid, maybe too good. Hard to get it smooth enough for my use. Also, I saw a piece that had been out in the weather for several years. The sun had worked on it pretty hard.
Old 12-14-2009, 01:26 AM
look at sea-dek, good stuff and pretty inexpensive cutting yourself and buying 4x8 sheets, easy to clean and soft too.
Old 12-15-2009, 01:40 PM
Mark Mark is offline
Go rougher than you initially think you need. Injuries due to slipping on a wet boat deck are costly, painful, and often un-fixable (speaking from personal experience).
Old 12-15-2009, 11:17 PM
I'm about to finish my console, transom, windlass, new electronics, etc. project and my wife does NOT agree with your cost assessment.
Old 12-16-2009, 09:56 AM
Who wears the pants in your family
Old 12-16-2009, 11:39 AM
Have you considered lying!
Just a thought....
See ya, Ken
