Old 01-03-2010, 03:41 PM
htillman htillman is offline
Default Sealant
What is the proper sealant to use when installing an outboard on the transom? I can see white sealant used under the mounting bracket and around the bolt holes and clear sealant to seal off the area in the large opening on the bottom of the brackets two bolt down areas.
Old 01-09-2010, 01:58 AM
Sandhog Sandhog is offline
Default Re: Sealant
I happen to come across this web site while doing a related search on Google - http://boatbuildercentral.com - you will find everything you need for repairs and modifications. Hope this helps.
Sandhog
"When the resolution of enslaving America was formed in Great Britain, the British Parliament was advised by an artful man,- who was governor of Pennsylvania, to disarm the people; that it was the best and most effectual way to enslave them; but that they should not do it openly, but weaken them, and let them sink gradually, by totally disusing and neglecting the militia." --George Mason, speech in the Virginia Ratifying Convention, 1788
Old 01-09-2010, 09:27 AM
Default Re: Sealant
Ed I usually use 5200 for the sealant around the motor mounting holes though it is a real pain to remove sometimes and it will take paint off along with it when time to remove it. 4200 is a lot more forgiving when it's time to remove. Make sure you coat the inside of the holes with a "penetrating" epoxy prior to using sealant around the holes. Not sure if it's the proper way
Check out 3M's site they have some good info on their adhesives/sealants. They have a new one out called 4000 which is UV stable for use above deck.
http://www.shop3m.com/marine-adhesiv...fasteners.html
