Old 01-08-2010, 11:59 AM
Default Ride of a 20SF
Has anyone rode in both the older 20SF, and the older 20SF with the reverse chine. I know some of the early 80s have the reverse chine and did not know if it rode better than say the 70s models without the reverse chine.
Old 01-08-2010, 02:22 PM
Default Re: Ride of a 20SF
I've ridden in both extensively. The model with the added lifting chine on the bow pops on plane just a bit faster, but has a slightly harsher/rougher entry in a moderate to heavy chop. Once on plane in a light to moderate chop, the ride is the same.
Old 01-08-2010, 03:15 PM
mnwnvc mnwnvc is offline
Fr. Frank- Do you know what year the design change occurred?
Michael
Old 01-08-2010, 04:57 PM
Thanks Fr. Frank.
So in your opinion does the hull without the reverse chine ride alittle better.
Do you know if they have about the same degree in the V at the front.
Old 01-10-2010, 01:43 PM
Thanks Fr. Frank.
Yes, I prefer the hull w/o the chine. I think they have the same degree of V, but I don't know that.
Old 01-10-2010, 03:42 PM
Thanks Fr.Frank. I maybe getting ready to trade a cuddy GW i own now for a 83' 20SF. Then may buy a 72' hull that needs some work. Was just wondering which one to keep.
Old 01-11-2010, 10:44 AM
While I like Grady's for their strength, sea-keeping ability and fishability, I would rather have either SeaCraft. As for the difference in the chine's on an '83 vs. a '72, I wouldn't choose a boat on just that basis. For instance, the '72 hull came only with a 20" transom, which is absolutely minimal with today's heavier motors; figure on redoing and raising the transom. If however, the very best possible ride is your goal, regardless of other modifications of repairs that may be necessary, then go for the '72 eventually. It may be, however, that you come to like the newer hull just fine. In that case, you're golden!
Old 01-10-2010, 01:41 PM
Michael
I think the 1st year with was '74. I had a '73 23' CC without the chine. I also had a '74 Tsunami that had it.
