Old 01-19-2010, 05:39 PM
ricko ricko is offline
Default are the 20'master angler more desirable?
just was wondering if they are worth more because the made fewer?
Old 01-19-2010, 09:03 PM
Default Re: are the 20'master angler more desirable?
The reason for me was the baitwell, here in Fla we use alot of live bait - the wide gunnels are really neat too, the GF loves that as you can sit just anywhere. Actually I think the design was done for the live bait crowd, in'75 it was becoming an important issue down here.
Old 02-01-2010, 04:16 PM
lunasea17 lunasea17 is offline
Does anyone out there actually use the transom live well on a 20 MA? Mine is really stern heavy just with a 140 Suzuki. How much water do you put in them?
Old 02-01-2010, 05:02 PM
I do - with a 200 Merc and it drains just above the lift ring, holds alot of bait - my intake is at the bottom and seems to work well. A top intake would not do as well I don't think and make the flow adjustable.
Old 02-01-2010, 06:10 PM
Do you use the origional plumbing?
Old 02-03-2010, 02:53 AM
They didn't come with any that I know of - we rigged the thru hull and sea cock at the dealer. Mine already had one when I bought it and then fills into the bottom of the well - although this wasn't a pretty install. The drain is just a standard 1 1/4" with a brass strainer thru the transom. I guess it might be possiable to exit the side but the well is pretty flush against the hull but would have a gap - that might wiggle a bit and be tough to seal. Be sure and mount the pump below the waterline or it won't draw right.
Old 02-05-2010, 12:56 AM
Mark Mark is offline
Beauty is in the eye of the beholder when it comes to the MA or the SF. I wouldn't buy a 'master angler' due to that 4" raised cap, which I think ruins the lines on an otherwise aesthetically pleasing hull. Others specifically seek them out. Worth more? no, not unless there is a buyer absolutely bent on having that model.
Old 02-05-2010, 09:38 AM
Guest
Posts: n/a
Mark,
What a great picture!! Gave me some ideas about an embroidered logo!!
Old 02-05-2010, 12:11 PM
Basspond Basspond is offline
Having owned both models, I can say Mark's image right there is what made me go to the SF the second time around. What nice lines.
2001 23 Regulator 2006 F250 Yamaha
Old 02-05-2010, 01:31 PM
same photo, less fussing:
