Old 01-23-2010, 03:17 PM
JohnB JohnB is offline
Default Trailer rims
I was towing back from the key this week, and had a rim failure. I split/blew out right on the bead. It looks like the wheel weights scraped off the galvanized coating, and after only 5 years, rust right through.
After looking at the other rims, it looks like I am in the market for 4 rims. I was thinking alum, or galv. at the worst case. Anyone know where to get some good used ones, or a source for new ones?
Rims are 5 bolt 14 inch.
JohnB / 23' SeaCraft
Old 01-23-2010, 04:23 PM
Default Re: Trailer rims
im not too sure where you are located, but there is a trailer shop in hialeah that has 14" rim and tire combo for 79.99.
Old 01-23-2010, 07:06 PM
Depends on your trailer and the back spacing . . . but Ford Rangers have a nice 14" aluminum wheel with a center hole large enough for trailer hubs. A full set of 4 with tires are often available on Craigslist for cheap The bolt pattern is same as a trailer. The weight of a ranger + max payload is well over the weight of a 23 with trailer + gear. I just bought a set of 4 complete with tires for $100.
