Old 01-25-2010, 01:03 AM
BoniB BoniB is offline
Default How to check a transom
I'm looking at at 20SF, if when I try to rock the engine and there is no play in the transom and no cracks in the glass how would you check it without a moisture meter? If there is no flex would it be considered ok?
tx
Boni-B
26 Regulator Express
74' 20SF
Old 01-25-2010, 08:32 AM
Default Re: How to check a transom
You can also remove screws and see what comes out, but that's usually with your own boat!
Tapping on the transom with a screwdriver handle or rubber mallet will also yield difft. sounds depending on its integrity. The hollower it sounds usually indicates a lack of integrity and a solid transom will yield little or no reverb.
Old 01-25-2010, 01:48 PM
Drill
Old 01-25-2010, 03:45 PM
Mark Mark is offline
Drill
Ah, the simple concise answer [img]/forum/images/graemlins/tongue.gif[/img]
(but taking out a transducer screw usually yields a wealth of info from my experience)
Old 01-25-2010, 04:52 PM
True, but the seller might not be too happy with that.
74' 20SF
Old 01-25-2010, 06:00 PM
Guest
Posts: n/a
Very true!!
Old 01-25-2010, 11:32 PM
I'm with Tim. Drill. Do it in 4 places, 1/8" holes x 1" deep.
Old 01-26-2010, 12:33 AM
Then what??
Old 01-26-2010, 08:25 AM
It would be pretty funny if you pull out a drill and tell the owner you just want to check a few things
Old 01-26-2010, 10:24 AM
Actually, I've done that. On a 25' Mako with twin Merc 200's, I asked permission to drill several holes in the transom, providing I plugged and re-gelcoated. I told him why I wanted to do it, and the owner said okay. So I did. I had 2 damp holes near the lower mounting bolts between the motors, and 8 dry holes. I bought the boat.
