Old 02-08-2010, 02:35 AM
CaptCurt CaptCurt is offline
Default used motor for 20 MA?
This is along the lines of a couple other threads in this section.
I am going to put a new(er) motor on my 20' Master Angler project. It currently has a 175 Merc (1979), which I have decided I don't want to fool with repairing. I am looking at several used motors, most of which are 150's. For the kind of water I'll be in, I don't really think I need anything over 115-ish.... but I don't want to under-power the boat.
What is the smallest motor I should put on a MA? Any specific motor recommendations? My price range is under $4000 if that helps any.
Working on my first project!
1979 20' Master Angler
Suzuki DT140
Old 02-08-2010, 08:23 AM
Default Re: used motor for 20 MA?
The smallest motor you should put on a 20' is the 2-stroke 85 hp Yamaha, which produced an honest 94-95 hp.
I think the best motors of the last 10 years for an original 20' SeaCraft that are readily obtainable for under $4k, because of their power to weight ratio, may be:
  • the 2-stroke 130 hp V4 Yamaha at 358 lbs, or
  • the '98-'04 2-stroke 130 hp V4 Evinrude at 349 lbs, or
  • the '00 to '05 Suzuki 2-stroke DT140 I4 at 364 lbs, or
  • the '99-'04 Mercury 125 hp Saltwater I4 at 347 lbs, or
  • the '02-'08 Tohatsu/Nissan HPDI 120 or 140 hp I4 at 347 lbs.
All are under 370 lbs, all produce at least 125 hp at the prop-shaft, all have good endurance records when meticulously maintained.
If I had a good service-providing dealer for any, I would choose the Yamaha. However, since the best local service in my area is for Mercury and Suzuki, I would choose on that basis. Never buy a motor for which you cannot get excellent local service. You need a good relationship with your outboard service provider.
Old 02-08-2010, 11:49 AM
Thanks Frank, that is exactly what I am looking for!
Suzuki DT140
Old 02-08-2010, 05:32 PM
After a little searching.... those are hard motors to find! Can anyone recommend a good source?
Suzuki DT140
Old 02-08-2010, 05:41 PM
I have 200 I would say 150 will work fine, you will probably find a better deal on them just because of availablity. The Mercs carbed or EFI are solid in 2.5L - I have an EFI and really like the FI. The Rudes are fine but not sure on weight difference between those two and that will have carbs only - go lighter. Do not go with the Rude DFI motors in that vintage but the carbs are fine.
Old 02-08-2010, 07:51 PM
Rude 150/175 365#s dry. Smoke and drink, but a good design.
Cheers,
GFS
Old 02-08-2010, 09:03 PM
I just bought a '77 MA with a '95 175 Johnson. Yesterday running into the wind(steady 15mph)and current I could get 28-29mph @ 4000rpm. 43mph @ 5600rpm. With the wind and current 31-32mph @ 4000rpm. 47mph @ 5600rpm.
That was half a tank of gas and my skinny arse.
Trim tabs and spray rails are going to be the first investment!!!
CaptCurt PM if you would be interested in the motor. I am planning to close the transom in and redo the rest of the boat next winter and was going to sell the motor then and go by a new motor. This will give me an excuse to go ahead and get some new power!!
Old 02-08-2010, 09:51 PM
Cheers,
GFS
thats pretty good my 200 is 416, not sure on 150 Merc's but that 50lbs would offset the baitwell I'd bet.
Old 02-09-2010, 07:26 PM
I just pulled the trigger and bought a 140 Suzuki, here's a link (until they take it down since it is SOLD!):
http://www.diamondsuzukimarine.com/Pre-Owned.htm
Any suggestions on props/pitch?
Suzuki DT140
Old 02-09-2010, 08:24 PM
Nice engine and I like the price
