Old 02-21-2010, 07:10 PM
newellchunker newellchunker is offline
Default Thru Hull (transom) repair ?
While I've been messing around I found that a thru hull fitting was piss poorly installed on my Sceptre. There is some rot around the thru hull and the areas immediate to it, the rest of the area out another half inch to inch are good....how is the best way to fix this....the thru hull was an inch and a half diameter. I'm planning on redoing the transom and installing a bracket in a couple of years and don't want to get TOO involved at this time.
Keith Willis 25ft Downeaster Pilothouse
Ford F350 Super Duty SRW
1977 SeaCraft Sceptre- SOLD
Old 02-21-2010, 07:34 PM
BigLew BigLew is offline
Default Re: Thru Hull (transom) repair ?
I'd build a plud and scarf it in.
Start with a 2-2 1/4" forstner bit thru a guide of 1/2" ply. Drill out a shallow (3/8-1/2) on both sides and then bore out the original hole to good wood. Make a plug laminated like you would do a transom and then set that in place and use the over-drill collars areas to finish it off both inside and out.
If you will be replacing the thru hull, be sure to line the hole with resin,thus sealing the wood core. Then replace the thru hull.
If you plan it out, step by step, and gather the needed materials ahead of time, it take a day or probably less. Just my 2 cents.
Good luck!
Plan accordingly!
