Old 03-01-2010, 08:14 PM
aldo aldo is offline
Default Soggy Floor - help needed
Pulled the floor section on my 23' Inboard. It is approximately 5' x 6' and spans over the two gas tanks. The outer skin is fine so I am just redoing the bottom.
I can probably match the way this was done- 3/4"plywood ribs and plywood squares.
My question is- Is there a better way to construct this with contemporary products? Am I better off making the ribs out of hard wood? Should I use divinycell?
What product should I use to attach the plywood or divinycell?
When all is said and done it has to span the 5 foot to the other side without touching the tanks.
I'm sure some of you guys have done this and I appreciate your input- trying to post images....don't know what I'm doing wrong.
[image]http://i749.photobucket.com/albums/xx135/Fred246/Floor2.jpg?t=1267483938[/image]
[image]http://i749.photobucket.com/albums/xx135/Fred246/Floor1.jpg?t=1267484982[/image]
Old 03-01-2010, 11:49 PM
Default Re: Soggy Floor - help needed
That is kinda broad, there is alot more to it than that, obviously you cut the deck out? How do you plan on putting it back down? Composites are the way to go (IMHO) but $$ may be an issue. You should decide which way you want to go, then someone can help. As far as posting pics go. Go to the pictures thread, follow the top thread.
1972 20' SeaCraft SF, F200XB
1974 40' Eagle
www.parkeryacht.com
Old 03-02-2010, 12:23 AM
On my 23 inboard the deck over the tanks is screwed down - no cutting that I'm aware of. Unscrew it and lift if out. I've never done it but it seems pretty straight forward.
You might want to follow the thread I think it was Strick's floor replacement in his new project. He did a total rebuild of the floor in his. Cut out the back and follow his example. If I remember right mine has ribs that the deck sits on for support.
Old 03-02-2010, 12:25 AM
[image]http://i749.photobucket.com/albums/xx135/Fred246/Floor1.jpg?t=1267500014[/image]
Thanks for your response- it is a removable section of floor-originally done (on the bottom)with 3/4 " plywood ribs on end and roughly 6" x 6" square plywood then glassed over. I followed chucks photo advice step by step, but still not working don't know what I am doing wrong.
Old 03-02-2010, 12:29 AM
Yeah, I have it out and on a frame right now. Strick is amazing and making the whole floor- I'm saving the skin and plan on rebuilding the bottom. Wish I could get the photo up.
Old 03-02-2010, 01:15 AM
I rebuilt this same floor /hatch on my inboard last spring. I pulled all the old plywood out and replaced it with 1/2" plywood squares ala Strick. Glassed over it with a layer of 1708. I beveled all the edges at a 45 angle so I could completely encapsulate the plywood. Originally some of the plywood edges were exposed which allowed water to rot out the plywood. So far so good --
Old 03-02-2010, 01:52 AM
SeaPlusPlus SeaPlusPlus is offline
Let me help with the pics, gotta get rid of everything past the ".jpg"
Old 03-02-2010, 02:07 AM
Here you go Fred. Just left click on the bottom dialogue box of each foto when in photobucket. It will flash "copied" then switch to CSC post and paste. [IMG] before "http:" and [IMG] immediately after ".jpg"
[IMG]http:examplei749.photobucket.com/albums/xx135/Fred246/freds/floorjibberish.jpg[IMG]
Good luck with the floor.
Old 03-02-2010, 08:16 AM
Thanks for the help with the photos! Think I got it.
Mine was a victim of water coming in the edges and the floor turned into a sponge. Deepsushi- Did you put ribs back in on yours or just the plywood squares? Are there materials that would keep the floor lighter and stronger?
Looks like I have a day or two of work just cleaning this up. [image][/image]
Old 03-02-2010, 09:43 AM
Not to change the subject, but why did they use plywood squares? The only reason I can think of is in case of water infiltration only 6 inches at a time get wet.
Keep the updates coming - I think my floor is not far behind yours.
