Old 03-18-2010, 11:27 AM
Andy5597 Andy5597 is offline
Default Transducer
What is best to re-use a in hull transducer, of unknown years or convert to a transom mount new transducer for Scepter 23 '76?
Old 03-19-2010, 07:43 PM
Default Re: Transducer
A shoot thru or thru hull will hold depth. Transom mounted are more problematic. Most are just not mounted low enough, at the proper angle, or by turbulence. Still learning.
Call the mfg.
Cheers,
GFS
Old 03-19-2010, 08:24 PM
bridgeman bridgeman is offline
what kind of a fishfinder are you installing?
Old 03-21-2010, 09:34 PM
At this point not sure which FF to install. Recommended to get a Raymarine C80 combo FF, CP, GPS. My budget is max installed cost $ 2500.
Old 03-21-2010, 09:57 PM
castalot castalot is offline
You CAN install the c80 yourself I did
do some online shopping you should be able to do at your price
if you want to see mine let me know
