Old 04-24-2010, 05:56 PM
captinseafood captinseafood is offline
Default A bracket for 25\" 150hp on 20' CC- Pros & Cons?
Hey everyone. I'm seeking advice on adding a transom bracket to my 1974 Potter 20' CC. I have to do the whole rehab this fall: replace the WHOLE deck, mod the rails and replace the fuel tank. I did the transom 2 years ago but now since I'm re-powering (great deal on 150 Ocean Runner) with a long shaft I have to mod the transom as it is for a short shaft. Since I'm cutting the deck up any way I'd like to re-do the transom with no cut out and add a bracket. Here are my biggest questions:
-Can I glass in ply over the cut out? Strong enough or do I have to re build the whole transom solid?
-What is the way to go- Glass bracket or Aluminum tube style?
-Are trim tabs necessary with a bracket?
Thanks in advance for any info!
Old 04-25-2010, 10:43 AM
Default Re: A bracket for 25\" 150hp on 20' CC- Pros & Cons?
*** Since the cut out area is not structural . . . you can glass over ply to fill the open transom.
Either is fine . . . Fiberglass won't pit or corrode like aluminum. You will want a flotation bracket regardless of the material it's made out of.
Absolutely . . . without any question!!
Also . . . if you are redoing the floor and replacing the fuel tank, move the tank as far as possible toward the bow. The bracket makes the bow of these boats very light.
Old 04-26-2010, 01:33 AM
Right on. Thanks for the response. After reading a bunch of the threads on this site, I have a better idea of what the whole project will entail... I'll try to post what I start with. I'm planning on starting a mold for a bracket this week. MDF like the one the Almighty Strick did. His threads kick ass! God my eyes hurt from reading so much INTERNERD......
Old 04-26-2010, 07:47 PM
Just an FYI - making a bracket costs $500+ in materials using Polyester, marine ply core/stringers and 1708. It'll take 3 - 4 weeks to complete if you throw a lot of free time at it. If you have time and don't mind traveling . . . you can occasionally find used brackets for $600 - $1000 on ebay and craigslist and for 2K you can pickup a hermco.
Old 04-26-2010, 08:07 PM
It's a shame you can't run on one to even see if you want the bracket....Some don't like them, some are all for it for various reasons..... I will say that if you were to do it you have a very light compact motor in mind, and that is a big factor. I'd love to get a nice 175 of that same block at a decent price..I'm sure if you've been searching posts you can see all the opinions, discussion, modifications...For me the good far out weigh the bad. I have a simple setup with a fairly light motor and no tabs and I love it.
Old 04-26-2010, 09:46 PM
makade makade is offline
I was wondering if anybody knows how the weights compare say hermco vs armstrong.
Old 04-26-2010, 10:00 PM
Ryan Ryan is offline
not sure on the weights but the big advantage to the hermco is the larger chamber.
Old 04-26-2010, 11:30 PM
SBD SBD is offline
FYI- you can get an Armstrong with a big chamber as well.
Old 04-27-2010, 09:00 AM
I was ordering a deckhatch from armstrong a few months ago and while I had the guy on the phone I asked about bracket pricing, etc. One of the things he said was their brackets are much lighter than the fiberglass ones. Was wondering if there really is much of a difference.
Old 04-27-2010, 10:37 AM
SBD SBD is offline
I just installed a wide body Armstrong with an 80 inch swim platform and the bracket was not heavy. Two guys could easily hold it in place. It probably weighed 70-80 pounds???
That said we got lazy and hung it from a forklift cause we had one!
