Primer/ Paint / Bottom Paint for Armstrong Bracket
I am refinishing my bracket. I have used a wire brush and removed all the corrosion. What primer, finish paint, and bottom paint (non-copper) would you use?
Snookerd |
Re: Primer/ Paint / Bottom Paint for Armstrong Bracket
chemical etch prime first,followed by epoxy barrier coat-interprotect 2000e...for the above the waterline area-i like awlgrip...antifouling area,i use and recomend trilux
don't skip the chemical etch prime before applying the barrier coat...primer,i really like duratec surfacer...
do not let common sense get in your way |
Pelican- Thanks for the specifics. That's a big help....
Snookerd |
