Old 05-12-2010, 02:30 PM
captdan captdan is offline
Default seacraft surveyors
HI,I'm planning on looking at a 77 seacraft and was wondering if there were any surveyors in or around the southern MA. area, That you may have used or know of. thanks Dan
Old 05-12-2010, 05:25 PM
Trayder Trayder is offline
Velvet Jones
Default Re: seacraft surveyors
Is it a 23 Sceptre? I think another member had it surveyed already.
Old 05-12-2010, 06:42 PM
No it's a 20ft master angler. Can anyone tell me how I could tell if the transome was bad? Besides the ovious transom hanging back an inch or two? Does the transom hold water? Why is it these transoms all need repair?
Thanks Dan
Old 05-12-2010, 08:47 PM
I used one from here...
http://www.marinesurvey.org/
Old 05-12-2010, 09:36 PM
30+ years is about the expected useful lifetime of a plywood transom. Remember to set your expectations appropriately when looking at these boats.
Old 05-12-2010, 09:41 PM
If it has a motor mounted, you might be allowed to stand on the cavitation plate - use your weight to rock the transom. If it flexes its probably wet and will eventually need attention. You can also rap on it with a mallet or the like. Check for resonance variations in sound, much like when trying to find a stud on a wall. Best sound will likely come from areas that haven't been drilled near. If it has some screws in the transom, you might ask if you can remove a few and jam a twisted corner of paper towel in there to see how much moisture it absorbs. You can also get a moisture meter at a wood/hardware store and check the moisture that way. But face it - unless it is a virgin hull, there will be moisture within the transom. But I wouldn't call it a deal breaker.
Cracks along the top of the cutaway or the cap might hold clues of water intrusion, too.
Also push on the inside of the transom under the spashwell. Sometimes the woven roving there separates from the wood and that will almost always cause a bigger problem.
Eventually, transoms need to be replaced. The transom is cored with 2 sheets of 3/4" marine ply and wrapped in fiberglass, resin, and gelcoat. Once that exterior (or interior) coat is compromised, the water ingress will begin. Water will eventually rot wood and cause laminate separation. Any wood, on any boat. Consider this hull is 33 years old. You don't hear much about it with other boats because most people don't feel their "other" boat is worth the time or money to restore once it's 20 years old. Those other boats don't have a SeaCraft hull. Obviously you are interested in a SeaCraft, because either you've ridden in one and know the feel or are convinced that those that have, and do, do so with good reason.
My 72 Seafari has cracks in the top of the transom, exposed wood, and I've over-drilled & patched at least 30 holes from previous transducers, hoses, ladders, aux motor mounts and God knows what else. Most of those over-drills extracted moist mulch. But with a light old Merc 115, the transom is still stout and I probably won't touch it for another year or two when Pres. Obama's eco-groupies ban my 2 stroke.
Good luck. I hope she proves worthy!
Old 05-13-2010, 01:15 AM
Thanks Mcgillicuddy! I'll check those things out.
I'm just waiting for the phone call to go view this boat.
Dan
Old 05-14-2010, 10:19 AM
pelican pelican is offline
Thanks Dan
transoms:
alot of transoms are damaged by owners and technicians installing things in a sub standard way-water leaches in,and the rest is history...
testing"
easiest way is to use a small ball peen hammer,tap the glass-listen for a sharp distinct sound,if you hear a dull thud,you hit a bad spot...do this test around any and all entry points-drains,engine,transducers...
i've seen surveyors ues a moisture meter,the meter read zero,i removed a transducer,and the water came running out of the core...lesson here is,make sure the moisture meter is working...
