Old 06-27-2010, 11:47 PM
newellchunker newellchunker is offline
Default Resin Question??
Ok, I did my transom lay-up with marine plywood with some left over epoxy resin that I had.....now I'm out of epoxy and still haven't installed the transom yet and need opinions of what type of resin should I use. Again, remember I'm a fiberglass novice and will be finishing my transom and then I will be redoing the floor. I'm kinda leaning towards vinyl-ester .....I'm on a strict budget but want the best bang for my buck.....ideas/opinions are needed and appreciated!!
Keith Willis 25ft Downeaster Pilothouse
Ford F350 Super Duty SRW
1977 SeaCraft Sceptre- SOLD
Old 06-28-2010, 02:35 AM
Default Re: Resin Question??
Rule of thumb is that you can epoxy over polyester but you cannot put polyester over epoxy. Vinylester I'm not sure about but since vinylester and polyester are compatible I would not want to take the chance of using vinylester. You should finish the transom in epoxy since that is what you started with.
Old 06-28-2010, 07:23 AM
Strick is correct. Stay with Epoxy plus it holds much better to your existing hull. For me all repair work use Epoxy and for new construction pieces you have a choice.
FellowShip
Just for the Grins
Old 06-28-2010, 09:12 AM
bigeasy1 bigeasy1 is offline
As mentioned,stay with the Epoxy.Polyester and vinylester resins will not cure properly over an epoxy resin surface.
Just for an experiment,I tried it with some polyester and vinylester resins,and they both remained gummy when applied over the epoxy.
The bond was bad,and it never completely cured.Don't risk it.
All this,just for a boat ride
Old 06-29-2010, 11:58 AM
Epoxy is a superior product one of it's best attributes IMO is the fact that you have so much working time so wood really wicks it up nicely. Just make sure it's nicely wetted out around all wood you don't want dry spots or voids.
Old 06-29-2010, 02:24 PM
OK, Epoxy it is.....NOW, the CHEAPEST place to order from???
Old 06-29-2010, 02:54 PM
My preference is Aeromarine, in California call or find on eBay
Old 06-29-2010, 05:19 PM
Thank You Bruce!
I was looking at them and also US Composites in Fl....they are pretty much inline price wise. Didn't know if anybody had any other cheap leads!
Old 06-29-2010, 05:46 PM
dbiscayne dbiscayne is offline
I've been using Glue Products in west palm beach, fl, 561-833-1863, for a long time. Never had an issue with their resin, epoxy ends up costing around $38/gal for the 1:1 or 2:1 mix, not sure if they ship though.
Old 07-04-2010, 09:36 AM
WillyC WillyC is offline
I used Raka epoxy and think its a great product. The six gallon kit is $288 and the three gallon is $156.
