Old 07-26-2010, 11:59 AM
BoniB BoniB is offline
Default Fuel Problem (Collapsing primer bulb)
Kept having this problem Saturday. Engine would be running fine then just die; checked the primer bulb and found it collapsed. Got it firm and ran some more; as i felt the bulb go soft the engine would bog down ....when I pumped it the engine would start running better.
I suspect a restriction in the fuel line upstream of the bulb. The fuel filter is only a week old. I disconnected the fuel line going into the filter/ water separator and blew back towards the tank. Seemed like at first I felt a restriction but thought that may be the fuel in the line. After a second or two there was no resistance blowing towards the tank. Reconnected everything and ran the boat for about 20 minutes with no problem.
Any advice?
Thanks,
John
26 Regulator Express
74' 20SF
