Old 07-27-2010, 05:03 PM
bigeasy1 bigeasy1 is offline
Default New Floscan Gallons per hour test
Installed my Floscan on my Tsunami 350 ci.I/O,and it is one of the best things I ever did.
** 5200 RPMS----------- 21 GPH
** 3200 RPMS------------ 9 GPH
** Trolling speed--------1.5 GPH
** T8 Yamaha kicker trolling speed---doesn't even register
This was without a doubt one of the best things to have on board,especially when making long runs.I filled up the tank and put several hours on the boat.
The totalizer digital readout said that I burned 13.3 gallons.When i returned to the dock I gassed up and it took 13.25 gallons.
It's nice to see where the optimum speed vs fuel burn and economy is.No more hoping the gas gauge is right.This is going to be a big peace of mind factor when we commonly make 20 -30 mile runs.
All this,just for a boat ride
Old 07-27-2010, 05:52 PM
bridgeman bridgeman is offline
Default Re: New Floscan Gallons per hour test
Thats next years toy for my baby, just couldn't justify it this year...needed to put a roof on the garage to keep her in all winter.
Old 07-27-2010, 06:57 PM
Amen brother!!! I love my fuel flow guage, lets me know what I burn on an average trip, GPH, etc. Wish I had bought one years earlier! It now comes down to simple math versus the not so accurate gas guage.
Old 07-27-2010, 08:17 PM
Basspond Basspond is offline
Love my floscan. I had to replace the flow sensor on mine and once I did that it worked as advertised.
2001 23 Regulator 2006 F250 Yamaha
Old 07-27-2010, 11:03 PM
which one did you get.
Old 07-28-2010, 04:41 PM
bigtahuna bigtahuna is offline
What I like about the Floscan is it allows me to make trim adjustments and watch as the engine RPM's rise and boat speed go up at the same time as fuel burn goes down. Then as you pass the optimum set the RPM's start to go down and fuel use goes back up letting me know right where to set trim for best GPH. It's a nice tool to have.
Old 07-29-2010, 09:29 AM
I bought the 5500 cruisemaster series.It has a needle gauge showing GPH and a digital display showing gallons used.
The also have more sophisticated all digital models that incorporate a tachometer and other data.but the cruisemaster was a lot less money and fit the bill for my use.
http://www.floscan.com/html/blue/ser...sid=11&catid=2
Old 07-29-2010, 01:29 PM
PackRat PackRat is offline
I have a 24' Topaz with a 350 (250 hp) Mercruiser and have looked at installing the digital tach/ flometer combo unit as gauge panel space is limited and this would drop in existing hole.
While digging thru installation details looks like an extra part might be needed - pulsation damper - for mechanical fuel pumps. Did you have to install this? Any issues?
Don't have any feel for how big the damper is and have not pursued it any further.
Thanks for any info you can provide.
Old 07-29-2010, 02:13 PM
Sorry...disregard that last question. Ended up calling Flo-scan and their tech advised that no pulsation damper is needed if you have an engine mounted spin-on water seperator/filter..maybe I missed this detail in their install manual.
Old 07-29-2010, 04:35 PM
I actually ended up using two water separating filters.I installed one filter a bit up from the tank outlet.Then I mounted the sensor,after that,and then I went from the sensors outlet to the engine mounted water separator.No need for a pulsation damper,as you mentioned.
I did this because it gave me enough of a run to make the fuel line run uphill as Floscan requires.
Plus I figure with the Ethanol fuel,it doesn't hurt to have another filter.
