Old 08-10-2010, 07:27 PM
BillPutney BillPutney is offline
Default fuel disposal
I have about 70 gals. of 2 yr. old gas in my tank.What is the best way to drain it , and then what to do with it ?
Old 08-10-2010, 09:45 PM
Default Re: fuel disposal
I picked up a 55 gal HDPE drum from a local feed store and drained my tanks by gravity. Our county has a toxic waste disposal site that accepts stale gas. Yours might too. If it's gone to varnish, don't even think about running it through an engine. I made the mistake of trying to burn some in my generator and had to pull the engine apart to get the valves unstuck. What a mess.
Dave
Blue Heron Boat Works
Old 08-10-2010, 10:02 PM
TUGBOAT TUGBOAT is offline
After Moving Way up North (Melbourne,Fl) I had 50 Gal. of gas for about 2+ years. It had Oil, Additive etc mixed. It burned,smelled good (No Varnish) etc.Couldn't find a way or Place to get rid of it.. Placed a ad on Craigslist & explained everything, Fellow showed up w/ containers for Half next few days came & got the Rest. He said the size of His Tank Mixed He didn't care.. Easiest I've found Just let em' Know it is Old. (Was Not Ethanol). Good Luck!
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 08-11-2010, 06:51 PM
newellchunker newellchunker is offline
Where r u locate in Eastern NC...I mite can be of assistance! I've got an electric fuel pump rigged up for this purpose.
Keith Willis 25ft Downeaster Pilothouse
Ford F350 Super Duty SRW
1977 SeaCraft Sceptre- SOLD
Old 08-11-2010, 07:46 PM
WILSON , I have a new twist to the story today . If I can rem. how to post a pic , you won't believe what I found when I removed the filter late last night. Yhe top of the filter is covered in what looks like uncooked grits . white , tan dark brown perfectly dryed crusty BS
I have never seen anything like it.!!!
Old 08-11-2010, 10:02 PM
I used up some 2 year old gas in my ole Dodge truck.
Dumped 6 gallons at time in when I would go to fill up..
It even had TCW 2 or 3 in it...
Trucks valves had never been cleaner!
This was many years ago when the truck had 50,000
miles on it. Today she has 285,000 and still going strong.
See ya, Ken
Old 08-12-2010, 10:06 PM
WWP2, if I were u, I'd invest in a cheap electric fuel pump...pump it out and run 5-6 gallons in my truck...thats what I normally do with old fuel.....mixing it with a fresh tank. If you dont want to do that...I'll run up that way sometime and pump it out and burn it for ya! Let me know what you think.
Old 08-15-2010, 11:34 AM
bigeasy1 bigeasy1 is offline
Previous to my restoration,my Tsunami sat in a field for six years with about 45 gallons of gas in the tank
We siphoned it out and guys at work put it in their pickup trucks and tractors.
None of them had any problems with it.They were more than happy to get free gasoline.
I,on the other hand didn't dare try it.I was just happy to get rid of it.
All this,just for a boat ride
Old 08-17-2010, 07:48 PM
I'm the poster to this thread originally .An update , I drained the gas and it looked and smelled just like some fresh gas that I had. I mixed about 10 gals in my truck tank with 7 gals of gas already in the truck .What a F - up
The truck cranked and drove for about 2 mins . It spits , jumps ,coughs and every other noise you can think of.It will not continue to run when you put it in gear .I am an Idiot , my wife laughs at me , This really sucks
Old 08-17-2010, 10:10 PM
Bummer! How many more gallons will your tank hold? Maybe change your inline fuel filter a time or 2 (I assume truck has one) Then either drain the tank or top it off with high octane or pour in some octane booster). Hopefully the sediment in the old gas just clogged up the little filter and it clears up some by changing the filter.
10:7 bad gasoline ratio was maybe a little extreme...hope it gets right for you. Good luck.
