Old 09-09-2010, 01:55 PM
boat_ri_m boat_ri_m is offline
Default gas tank dimension for 1989 20 ft center console
I have a 1989 seacraft 20 ft center console. It says "Tracker Seacraft" on the side of the boat but the title says the manufacturer is a seacraft. I called Tracker and they told me Tracker has owned Seacraft since 2000 and therefore wouldn't have the dimensions? I need to replace the tank and was wondering if someone can provide the dimensions. It's about a 72 gallon tank. Any help is greatly appreciated.
Old 09-09-2010, 10:16 PM
Default Re: gas tank dimension for 1989 20 ft center console
I have an `89 20 sf. AFP. They became RDS. They have the Dwigs. Many years. Outta Perry Fl.
Tracker is still chasing saltines. No clue. They were the parent co. then.
BPS knows more about the old slackers than the folks that made them. That was slacker.
Cheers,
GFS
I know the boat. Ask away.
Old 09-10-2010, 10:34 AM
Pull the old tank and measure it. Send photos to RDS. The can then duplicate the tank.
BTW, Tracker bought SeaCraft in '87.
Old 09-10-2010, 11:30 AM
I was hoping to find the dimensions before taking it apart. I want to put in a smaller plastic tank (~45 gallons) since I've been having ethanol problems (I only use about 100 gallons/year plus it's the original tank). So if I knew the max dimensions I could order one since some of the larger plastic tanks have a long lead time.
Thanks for the info.
Old 09-10-2010, 11:53 AM
My tank is 47 useable.
Dwigs=Architectural drawings. Call them.
Cheers,
GFS
Old 09-11-2010, 10:21 AM
WillyC WillyC is offline
The tank in my 1975 20sf was 24"x60" and 8" tall. Thats slightly less than 50 gal.
Old 09-12-2010, 07:57 AM
mnwnvc mnwnvc is offline
Is your tank above or below deck? If above and under console I can send you the dim. of mine. Never totally filled mine but would guess 35 to 40 gal.
M
Old 09-12-2010, 08:44 AM
Mine is below deck......but thanks for the offer.
