Old 09-15-2010, 08:56 PM
geesea geesea is offline
Default wet sanding hull
Can anyone advise the initial and final grit to use wet-sanding a hull? I just removed an ugly painted on boot stripe using paint stripper and want to even out the gelcoat on my 23 savage. Compounding was not aggressive enough.
Old 09-15-2010, 09:38 PM
Default Re: wet sanding hull
If you have serious oxidation on the gel coat I would start with 600 if not start with 800 then to 1200 then up from there to 1500 before you start waxing.
FellowShip
Just for the Grins
Old 09-15-2010, 09:55 PM
If you use Poly Glow instead of wax, you can finish with the 800 grit.
Dave
Blue Heron Boat Works
Old 09-16-2010, 12:10 AM
Just buff it with tigercut. Then work your way down the line.
Old 09-19-2010, 08:56 AM
red20 red20 is offline
I have a Harbor Freight air powered orbital wet sander that makes the process VERY easy.
Old 09-20-2010, 09:39 AM
SBD SBD is offline
I have been wet-sanding my arm off!!!Considering getting a air wet sander...gotta pn for the one from HFT?
Were do you get paper for it?
Thanks!!!!
Old 09-20-2010, 03:23 PM
If you are wet sanding your arm off, you are not coarse enough. If you start out with 1500 you will be at it for a while......
Old 09-20-2010, 07:10 PM
SBD SBD is offline
I have been starting with 400 and working my way to 1500...but I am doing a big area.
Old 09-21-2010, 02:22 PM
I don't have the HFT part number handy. As for the paper, I buy the grit desired and cut it to size. Then take a used up pad (no wet sand) from other projects and spray glue the wet paper to the old pad. I cut out some of the holes and sand away.
Old 09-21-2010, 09:24 PM
3rdday 3rdday is offline
Walmart has a dual action random orbital, about the same price as HFT.It will give you better results than a random orbital, and it is faster. Additionally I trashed 2 of the harbor frieght in surprisingly very short order. I am a fan of HFT and have many of thier tools.
