Old 10-04-2010, 05:05 PM
swalton12 swalton12 is offline
Default 23' CC Trailers
I will be soon be acquiring a 1975 23' CC, but will need to haul it and am looking to buy a trailer. Does anyone out there know what 23' trailers do and do not work for this boat? I know I need a tandem axle but am not sure if any easy loader or venture will do if at all.
Old 10-04-2010, 06:11 PM
Default Re: 23' CC Trailers
I recently weighed my 23' cc on alum. trailer and it's 6600# w/~ 125 gal fuel, t-top, 2 batts., anchors, etc.
Old 10-04-2010, 08:43 PM
castalot castalot is offline
i have a 5200# capacity 5 star trailer all rollers disc brakes on front axle torsion axle love it towed empty to south jersey and back with my boat towed like a charm and loads and unloads nice i think its a 7000# gross
Old 10-04-2010, 10:21 PM
I have an aluminum bunk. It is a 2-axel, torsion, disc brake trailer. I think it is 7000# for my 23 inboard. I tow it every year to the Keys and it tows very nicely. I can’t post a picture but I will email you one if you need one.
Old 10-04-2010, 11:14 PM
Welcome to CSC swalton!
I don't know your home port, but if you are towing in Fla the new regulations require brakes on all 4 wheels if your over 3000#. Be sure to check your State requirements.
Good Luck with your new rig
BTW Tucker, the Monroe County Sheriffs (Keys)now have portable scales that look like door mats that they place in front of your trailer tires and you drive onto them and that gives them the combined weight of the trailer and contents and if you exceed the 3000lbs than yes you can be cited for it. I hear it's $500 ?
Old 10-05-2010, 08:57 AM
First of all there are several exceptions to that law. If you can stop your combination vehicle in 40 feet or less from 20 mph using the towing vehicle brakes, you do NOT have to have any brakes of the trailer at all, regardless of the weight of the towed vehicle. [FS 316.262(C)c-4] Most dually pickups with ABS, pulling 5000 lbs or less of trailer weight can do this. Some single rear wheel pickups can do it as well.
Just for grins, I tried stopping my 20' Seafari in 40' or less in a parking lot using my '02 F250 Crew Cab diesel with 4 wheel ABS. Total towed vehicle weight is about 3400 lbs on an older tandem axle trailer with no brakes. In 5 tries, I stopped in 40' or less 3 times. Best was about 37'. Worst was 41', twice.
As far as the fine goes, it's not $500, unless you're using an apportioned commercial tow vehicle pulling a permanently licensed trailer.
Rather, the law specifies a flat fine of $60, plus additional costs of $4 to $35, depending on county and circumstances. [FS 318.18(C)b]
Here's the good news: trailers manufactured prior to 2009 are "grandfathered" and are exempt from the new brake regulations, but still bound by the existing law in effect on the date of their manufacture.
Old 10-05-2010, 09:23 AM
My two cents worth.....the cost of SS disc brakes on all four wheels is worth every penny if you tow long distances. I don't tow my 23'er too often at 20 mph going down I-75, across Alligator Alley or down US1. To me 20 mph seems like a rather goofy government regulation. After one very close call I'm very happy I had the upgraded brakes added when I ordered the trailer.
Old 10-05-2010, 09:23 PM
kerneltugboat kerneltugboat is offline
I think the all Stainless Kodiaks are worth every penny, even if you trailer short distances, it my opinion it is the sitting doing nothing after being dunked in saltwater that does most of the Damage. I bought a 12K Hi-Tech All stainless Hardware Float-On 8 years ago and had zero issues with the trailer or Brakes. My dad bought the 7K Hi-Tech about 6 years ago, but could only get the e-coated brakes at the time and they were done after 4 years, Kodiak has a kit with all Stainless Calipers and pins, with Cadnium coated rotors and mounting hardware that may be better than the e-coated, but not as good as the all stainless, but much cheaper especially if you have to do both axles.
It's not a Small-Craft, it's a Seacraft
Old 10-05-2010, 10:29 PM
how many of you tow your 23 with a half ton rated truck??
mine is rated to tow 7200 pounds. according the reelscape his is 6600. i think thats a little close to the limit. around town a few miles to the ramp is probably ok but on the highway forget it.
Old 10-11-2010, 08:17 PM
Thanks for the welcome and thanks to all for your help. You all have been more helpful than the dealer. They seem to think a 5kGVWR trailer will be more than adequate, but you guys seem to mostly have 7k trailers. It will be for a longer haul around 600 miles intially. Any opinions on Venture trailers anyone? To bad there aren't a lot of good used trailers out there!
