Old 10-08-2010, 03:21 PM
shine shine is offline
Moderator
Default 23CC - gap between striner top to liner?
Does anyone have a measurement of the gap from the top of the box stringer to the base of the cap/sole? Will be replacing a new sole directly on old stringer top (leveled out stringers ). I have seen a number of these boats with quite a gap. My goal is to find the original sole height so I don't put the new one in too low.
Thanks!
Old 10-08-2010, 04:24 PM
newellchunker newellchunker is offline
Default Re: 23CC - gap between striner top to liner?
Shine,
I cant help you, but I believe that most of these guys raise the sole (floor) a couple of inches when they replace their floors. I'm sure someone will chime in and give you a definitive answer. I'm redoing a Sceptre and am gonna leave it the original height.
Keith Willis 25ft Downeaster Pilothouse
Ford F350 Super Duty SRW
1977 SeaCraft Sceptre- SOLD
Old 10-08-2010, 06:07 PM
on mine its about 2 inches.
Old 10-09-2010, 09:14 AM
bigjim2500 bigjim2500 is offline
mine is 1/2" on the port side, not sure about the other.
1979 23cc
Twin 98 Johnson 225s
Old 10-09-2010, 09:18 AM
If I understand your question correctly.
When originally built they put resin putty on the top of the stringer to adhere to the bottom of the deck and inner liner (all one piece) to create a solid piece. That gap is approx 1” at least on my boat. Over time that putty broke and cracked and did not adhere very well to the deck and also could cause pressure dings on the top of the foam filled stringers.
The method of redoing the deck determines what you should do.
If you are Not going to raise the deck up 2-4” but keep it as is you could just remove the top layer of glass remove the core material and replace with new core material and replace the top layer of glass.
If you are going to raise the deck up then you should keep a 2” rim all around the outer deck for support plus add additional lamination to the rim and also to the stringers to mach that height. Then laminate your deck on both sides with glass adhere it to the stringers and deck rim glass additional layers to fuse it into the inner liner and finish it off.
On my 23’ I did not raise the deck, on most 20” and smaller they raise the deck. If you have a 23’ and are going with twin configuration I would raise the deck to keep the scuppers above the water line.
FellowShip
Just for the Grins
