Old 11-08-2010, 09:30 PM
boatdotbay boatdotbay is offline
Default 20' CC -- where to locate tank/center console
Hi,
My brother is picking up a 1974 20' CC that needs to be rebuilt. The boat will get a bracket along with a 115 - 130 4stroke.
He's going to build his own center console is there any recommended location fore/aft to put the center console to help balance the boat? He also needs to put in a fuel tank -- recommendations on maker and how far forward to place it?
Thanks!
Old 11-09-2010, 08:22 AM
Default Re: 20' CC -- where to locate tank/center console
Lots of good tank manufacturers out there. Several in Florida. I used RDS Aluminum for a duplicate of the original tank for my '72 Seafari and I am well pleased. They are in Perry, near Tallahassee. They can duplicate or do custom tanks.
Old 11-10-2010, 06:26 PM
seacraftks seacraftks is offline
Greetings
My recomondation is to set the tank in the middle of the boat and about 12 inches aft of the oringal postion you will find you have a better ride
Old 11-10-2010, 06:37 PM
Most folks move tank (and batteries) FORWARD because today's motors are so much heavier than what these boats were designed for in the mid-60's! If you shift the CG aft, don't expect it to ride or perform the way it was designed to!
Old 11-11-2010, 06:55 PM
palmettohotfisch palmettohotfisch is offline
I am positioning my tank as far forward as I can and setting the batteries under the console on my 20'MA. The new tank will be 50 gal and 75" long. My thoughts on this are same as Bushwaker said - motor is heavy and hopefully not too much weight in the back and some good scuppers may keep the water out. I am setting a new (smaller) console in the same general area as the old one.
