Old 12-20-2010, 01:20 PM
KenB KenB is offline
Default Gelcoat Versus Awlgrip versus Easypoxy - showdown.
Hi folks.
I now have 2 (two) seacraft projects on stands and blocks, and instead of sanding, faring, or replacing decks/transoms, I would rather spend my time posting about painting the hulls (i.e. the last step). I know there are several great threads covering the benefits of all three approaches, but I would like to get all the relevant information into one thread. Someone did this a while ago with "twins on a 23", where most of the relevant info needed for repowering a 23 was concentrated in one mega-thread.
To be specific (and please correct me if I am wrong) here are the 3 scenarios:
1) Gelcoat - by this I mean buying Gelcoat from jamestown distributors and DIY. remove bottom paint. repair dings, gouges, etc with poly/glass. Quikfair. roll on Gelcoat. Sand. Roll on again. Sand.
2) Awlgrip - by this I mean professionally sprayed paint. Pros sand blast bottom. DIY repair dings, gouges, etc with poly/glass. Quikfair. DIY Primer and sand. Pros shoot paint.
3) Easypoxy - by this I mean roll and tip epoxy paint. remove bottom paint. repair dings, gouges, etc with poly/glass. Quikfair. high build primer. Sand. Roll and tip. Sand?
There are 3 things I would like to compare: cost versus quality of finish versus time I spend doing stuff.
Cost (Total WAGs - wild ass guesses):
1) Gelcoat: seacraft23 - $500,seacraft23 - $500,
2) Awlgrip: seacraft23 - $6000,seacraft20 - $5000,
3) Easypoxy seacraft23 - $1500,seacraft20 - $1000,
Quality
1) Gelcoat: new boat.
2) Awlgrip: better than a new boat.
3) Easypoxy seacraft23 - new boat... from 25 feet.
Time
1) Gelcoat: 2 paint/sand cycles
2) Awlgrip: 1 paint/sand cycles
3) Easypoxy: 3 paint/sand cycles
OTHER QUESTIONS:
- below waterline versus above waterline (i.e. hull versus decks, console, etc.) I am leaning towards gelcoat on hull and easypoxy above decks on the 20, since that hull is in serious need of TLC.
- below decks? I have heard some folks slapping on a coat epoxy primer. Overkill?
- how much does the current state of the boat matter? My 23 had solid gelcoat... I may just do a few repairs and try to color match the gelcoat. The 20 is a mess. Both structural stuff
IF THERE IS A THREAD THAT ANSWERS THIS, PLEASE LINK AND POINT ME TOWARDS IT!!!
Old 12-20-2010, 03:57 PM
ct9amr ct9amr is offline
Default Re: Gelcoat Versus Awlgrip versus Easypoxy - showdown.
You can see some before and after of my old Shamrock here. It was a 1992 with original gelcoat but it was too far gone to bring back.
This was all professionally done bottom job and top.
Awlgrip on sides and bottom paint is vivid white.
Glen
Old 12-20-2010, 08:41 PM
You might want to consider one other option . . . Signature Finish paint. Durability similar to Awlgrip but it's easily repairable which awlgrip is not, and can be applied via roll & tip or wet roller/dry roller. Will hold up under water, which no other urethane paint will do. Can be any color you want - just tell them brand and color name/code. Appearance can be equal to awlgrip if you're willing to do a little buffing. Capt. Chuck is resident wizard on this paint. Contact Tom for cost. Cost would probably be more than Easypoxy but less than awlgrip. Application difficulty similar to easypoxy.
Here's a link to my bottom painting project.
Old 12-21-2010, 01:25 PM
SBD SBD is offline
FWIW- I have been doing lots of gelcoating on my project and I tried rolling initially and the results were not good. I wouldn't recommend it.
I switched to spraying and the results have been great, but making the final product go from good to great is labor intensive. In hindsight, paint would have been much easier, which is probably why it is the way most people go!
Old 12-21-2010, 10:13 PM
bigeasy1 bigeasy1 is offline
I sent you a pm on the gelcoat.
I wouldn't use gel coat,It's way to labor intensive to get a perfect finish.
I'd definitely go with paint,and I wouldn't go with the EasyPoxy.The EasyPoxy is a single part urethane,and although it's a real nice durable paint with a very nice finish,It can't come close to the two part urethanes like Awlgrip,Signature,Perfection, etc in the durability,gloss or longevity factors.
The perfection(Interlux) works great with the roll and tip method and many guys say the same about the Sterling.I used a two part urethane made by Epifanes on my 23 and although I sprayed it,it also works good with roll and tip application.
These two part finishes are incredibly durable and highly fade resistant.They are the way to go.
Check out www.Mertons.com look at his gel coat and compare it to Jamestown.He also ships fast and everywhere,and carries lots of paints.He has just taken on the Interlux Perfection line and his prices and service are outstanding.
All this,just for a boat ride
Old 12-21-2010, 11:16 PM
After 40 years of trying to make Gel Coat look good on
a boat, I gave up!!!!!!
Take it from some one that has been there an done that!!
Use AwlGrip!!! Yeah, it is a pain in the azz to use,
and a bit*# to spray, but the end result is what you
are looking for...
Just my 2¢'s worth.
See ya, Ken
Old 12-22-2010, 10:47 AM
My take on this...2 part paint. If you are doing a whole boat such as my project skip the roll and tip. Spray it or have it sprayed, you will be much happier with the results.
Old 12-28-2010, 08:13 PM
seacraftks seacraftks is offline
I agree spraying in one shoot is the best a couple of coats and you be done
Old 12-30-2010, 05:14 PM
thegoggleeye thegoggleeye is offline
Hey just my two cents; first off do not roll on gelcoat. it will be a mess you dont want to get yourself out of. gelcoat can only be so thick on a boat. the hardened resin does not flex and will crack if too thick (where spider cracks come from. the awlgrip is the way to go, that is why it is so expensive, but if the boat is stored outdoors you will get about 6 years out of the awlgrip.
mechanical engineers build bombs. structural engineers build targets.
Old 12-30-2010, 07:45 PM
I know of many people that store their boats outdoors and after 10 years their Awlrgip job still looks great.
