Old 01-01-2011, 04:50 PM
geesea geesea is offline
Default transducer location-inboard engine - seacraft 23
what would the best location for a transducer on a seacraft 23 inboard center console? Is thru the hull the preferred method?
Old 01-01-2011, 06:48 PM
aldo aldo is offline
Default Re: transducer location-inboard engine - seacraft 23
Mine is through hull directly in front of the engine and close to the keel.(port side)
It works much better that the transom mount I used years ago when I first got the boat.
Old 01-01-2011, 07:23 PM
bobbert bobbert is offline
Give the new Garmin flush mount/ thru hull transducer a look. Looks real slick.
Old 01-01-2011, 10:04 PM
My thru hull was starboard side just aft of the center console if i remember correctly. I had to build a fairing block on the bottom of the hull so it would echo right under the boat. Took some doing but, never lost bottom while cruising.
