Old 01-05-2011, 07:55 PM
DANNY18SC DANNY18SC is offline
Default 18 with a 90?
how do you think me 18 will perform with a 1990 90 hp Johnson with a 17 pitch prop? it is a 20" motor and my transom is 25". should i look for a 25" midsection or cut the transom?
78 18'
89 200 Yamaha
http://i1215.photobucket.com/albums/...1227/boat4.jpg
Old 01-05-2011, 10:40 PM
Default Re: 18 with a 90?
You need more than just the midsection; you need the right driveshaft to go with it. Don't cut down the transom. Let me repeat that: Don't cut down the transom.
Old 01-06-2011, 09:48 AM
since your boat has a 90, seems my 18 CC would do fine with a 90 and one day i could look for a bigger motor. anyone know of someone with all the 25" pieces for a 1990 90 johnson?
78 18'
89 200 Yamaha
Old 01-06-2011, 09:54 AM
I agree with Fr. Frank, don't cut the transom down. I wish mine was a 25". I don't have any problems with the 140 4s on my 20" transom, HOWEVER, you won't see me going out in snotty conditions. I spend most of my time in the Albemarle Sound and only go in the ocean on nice days.
Old 01-06-2011, 05:15 PM
http://www.baymfg.com/
This is what you need to make that 20" motor a 25"
Old 01-07-2011, 01:04 AM
You really need a 25" 115 at best, I bet you can do with a sale/swap in those years pretty easy. Sell yours and buy a 115, should be pretty even and easier
Old 01-07-2011, 01:31 AM
I agree - if you add the $ you'd spend on the 25" extension kit to what you'd get for current motor, you might be able find a newer 25" 115. The 90 (used to be an 85) and the 115 are both V-4's, so same block and about the same weight. However motor condition/compression is more important than age. Would be best to get a loop charged model (60 degree V) instead of the older cross-flow 90 degree V, but I don't know when they started making the loopers.
Old 01-07-2011, 10:14 AM
im trying to work a deal on a 140 looper. the guy has an extra motor and the extension kit. i dont have the cash at this moment since i just bought the boat but am trying to work a trade. thanks for all the input and advice!
78 18'
89 200 Yamaha
Old 01-07-2011, 10:52 AM
Some of the 88 and 112 special motors were crossflows into the 90's. v4 loopers were made in 90 - 140hp flavors (beginning in 86 or 87) . . . same block, same bore and stroke. I don't know for sure but I don't even think there were porting differences. You can do a little research . . . It's probably just changing carbs, heads, and tuner will be the difference b/w 90 and 115. This is true for Merc 2.0L 135 - 150, and 2.5L 150xr6, 175 vs. 200. Sometimes just swapping carbs will give you the extra 25hp. Visit www.screamandfly.com and you can figure out the differences in very little time.
Old 01-07-2011, 03:38 PM
Probably the biggest deterent to working 20+ year old motors is trying to actually do it. Bolts break or won't come out and it just becomes a nightmare of time and aggrevation.
