Old 02-27-2011, 06:33 PM
castalot castalot is offline
Default Dive ladders
Does anyone have an Armstrong dive ladder how do you like it is there anything you don't?
I'm need a ladder for the boat and was looking for used ones and wanted some advise on them
Has anyone tried any if the other similar ones like the gerlick(sp)
Thanks
Matt
Old 02-27-2011, 08:53 PM
Bryan A. Bryan A. is offline
Default Re: Dive ladders
I have a 3 step armstrong ladder on my Parker, fits into the armstrong bracket.
Works great!! Made a little modification to the retaining ring but other than that, works fine.
My 1973 SeaCraft 20SF
Parker 2530 DVEC
Boston Whaler 15 1984
htillman htillman is offline
I have an Armstrong ladder. The only thing I dont like about it is it is easily to leave on the transom. It will create alot of drag and bend the bracket. I have started putting a clothesline clip on the engine key to remind me to remove it.
Other than my forgetfulness, it is a great product.
Old 02-27-2011, 10:36 PM
Matt
I had one before my transom enclose. They work great, easy to install and they float. The big complaint I experienced was storage...
Old 02-27-2011, 11:04 PM
ct9amr ct9amr is offline
I put a windline on my contender.
It had an Armstrong but the plastic steps broke.
This was a great replacement and cost me less than replacing with an armstrong.
Windline Ladder
Glen
Old 02-28-2011, 10:49 AM
does anyone know how much they stick out i have twins and would have to clear the trim tabs
thanks
Old 02-28-2011, 09:34 PM
You are probably better off with something like this.
Platform Ladder
Glen
Old 03-01-2011, 12:29 AM
That's a good set up for most diving, although if doing tank diving, you might want a 3 step ladder, with platform mounted close to the waterline.
Old 03-01-2011, 06:30 PM
My swim platform, which is the one from Overton's listed above, is mounted with the top surface right at the waterline and I have the optional 3-step drop down ladder. I have no problem getting in and out with my scuba gear on, and I'm old and fat.
