Old 03-03-2011, 01:18 PM
geesea geesea is offline
Default tranducer choice for 23 inboard
I am about to purchase a furuno 585 sounder/thru hull transducer. Can anyone help me choose the correct one? I am looking at the airmar 1kw tilted element. Do I purchase the 20 degree one even though it is going to be mounted near the keel(centerline)of boat?
Old 03-03-2011, 11:44 PM
Default Re: tranducer choice for 23 inboard
If I remember right that one is pretty big bucks. I use a regular plastic/composit thru hull as a shoot thru the hull transducer. It works great down as deep as 1500 feet. I had issue with drilling a hole in the hull so I looked into shooting thru the hull.
Old 03-04-2011, 06:38 AM
can you elaborate as to what issue with drilling through the hull? Did you just not want a hole in the bottom of your boat or something else? Thanks.
Old 03-04-2011, 09:40 AM
I chose the Airmar tilted element with that same sounder and am very happy. You may ask Airmar about placement as mine is outboard power.
Old 03-04-2011, 03:41 PM
I have the exact same setup as Reelescape on my outboard- had major concerns about cutting hole in bottom but everything has worked out great- 585 is a nice unit and works great with Airmar tilted element.
Old 03-04-2011, 04:23 PM
I have the airmar tilted element installed in my inboard. Works great and holds bottom while running. It is installed on the port side just about amidships.
Old 03-04-2011, 10:33 PM
Everyone is correct on their call on the tilted element transducers. I've got the Airmar 20 degree and it works great. Had an issue with the cable from the original unit.....no questions asked by Airmar, period, they replaced the unit!!! Great customer service.
Form the "for it's worth department".....this is where you do not skimp on the purchase/install. If you are going to the effort and expense of drilling a hole in your hull to install the transducer spend the extra $$$$ and do it right. I've got the 1000w B164 and am very satisfied!!! Now that I have this unit, I will NEVER go back to a transom mount for any of my boats!!!!
Old 03-05-2011, 05:31 PM
tkbsurf tkbsurf is offline
I have the Airmar B744V Bronze triducer thru hull for my inboard with fairing block. I have an extra B744-V w/o fairing block if you need one.
1976 23' Sceptre inboard V drive
Merritt Island, FL
Old 03-06-2011, 11:33 AM
Just didn't want to drill a hole in the boat. I have a piece of 4" PVC cut on an angle to be perp to the water. I used 5200 to attach it low in the bilge just in front of the engine. Fill it with non toxic anti freeze and hang the thru hull transducer in it. I watch the depth drop to 1500 feet cruising @ 20mph.
Old 03-06-2011, 12:45 PM
Gary Hill Gary Hill is offline
I used a Aimar on my 23 Inboard, didn't want to do the large hole in the bottom but has been in the water most of the time (4 years) and no problems.
GARY
76 SEACRAFT CC INBOARD
