Old 03-12-2011, 07:37 PM
newellchunker newellchunker is offline
Default Boat support??
Since I've removed the cap, and finished my transom layup, I was wondering if I have enough support under my boat to keep it from spreading and causing me a problem like Strick had with his?? Here are some pics showing the boat on the keel supports and boat stands on the sides supporting it. Whatda ya think?
Keith Willis 25ft Downeaster Pilothouse
Ford F350 Super Duty SRW
1977 SeaCraft Sceptre- SOLD
Old 03-12-2011, 08:30 PM
Default Re: Boat support??
As far as the stands go you can tie them together...ratchet straps or something port to starboard
Old 03-12-2011, 08:34 PM
Hadn't thought about tying them together! What I was really concerned about is the hull getting deformed and spreading outwards and causing me major problems when I went to put the cap back on! Any ideas on this?
Old 03-12-2011, 08:50 PM
I think you've done a real nice and safe job of setting up. Regarding the spread, you may still want to consider notching a couple of 8' 2x4s and maybe a 10'er and lay them across the beam with notches over the open gunwale at a few spots just to be sure. Certainly wont hurt..
Strick or someone else might have a better sense of if it's necessary. Figure the boat's in its working place and since you know the potential for said side sag exists, why not counter now, especially if the project might take a while?
Old 03-12-2011, 11:42 PM
BigLew BigLew is offline
Less than $50.oo safe vs. $????.00 pain- your choice! IMHO Good luck.
Plan accordingly!
Old 03-13-2011, 12:07 PM
KenB KenB is offline
One version is to leave the cap on before cutting the decks, but the 20 thread on cape cod said that his hull seemed to bow out at the water line, not the gunnels.
On the one hand, new decks, stringers etc. mean the boat is in much better shape, even if it is actually a different shape. I think strick's boats look great so...
Old 03-13-2011, 07:34 PM
bobbert bobbert is offline
The only thing I would suggest is to put some big pieces of plywood under the jack stands to keep the legs from sinking into the ground.
They always seem to sink in at different rates and screw everything up.
Old 03-14-2011, 11:12 AM
I think you've done a real nice and safe job of setting up. Regarding the spread, you may still want to consider notching a couple of 8' 2x4s and lay them across the beam with notches over the open gunwale at a few spots just to be sure. Certainly wont hurt.
The spread occurs at the top. Measure your removed cap and then measure the boat to see if the they co-inside. If you are just replacing the floor then you will probably be ok. where I got into trouble on my 20 was when I decided to core the sides of the hull. That made the sides stiff and I was unable to flex them back to the original shape. Nice work.
